Old 01-12-2009, 10:37 PM
|WYG|SS |WYG|SS is offline
moving down hill?
93f150 4.9l 5spd. i was at my friends house whos house whos driveway is kind of a incline. i throw the truck in 1st gear everytime i park it their cause it is too steep for the parking brake to hold it. i was sitting in the truck fixing something and i thought my friend had walked up and pushed on the truck and it moved, but it wasn't the truck was still in 1st gear and every 10 sec(maybe longer). the truck would move a little. i would say it was slipping in the gears then grabed then stopped then grabed then 10 sec later it did it again. the truck moved 1ft in 5 min. i do have 230lbs of sandbags and salt in the bed. could the weight of the bed and me make it move?
Old 01-12-2009, 11:54 PM
dfordski's Avatar
dfordski dfordski is offline
Re: moving down hill?
Is it imported sand or domestic? Normal. Try turning the wheel all the way left or right, leave it in gear & setting the parking brake. If that dosen't work, its probibly the ol' "One last straw that broke the camels back" Senario (substitute "straw & camel" with "sand bag & F-150"). So take that last sand bag off (if you can't remember which one it was, guess! You might get lucky and pick the right one!) & set it behind one of your tires so you don't forget it when you leave. Is it still rolling back? This is a good example of what happens to your sense of humor after 14 - 12 hr shifts in a row.
Old 01-13-2009, 12:21 AM
mechhound mechhound is offline
Instead of slipping in the gears, I think the compression of the 6 cylinder engine wasn't enough to hold the truck and the engine was turning slightly. I have an '88 F-150 with that same engine and transmission and one day I parked on quite a slope near a convenience store as I was walking away I heard an rr I got back in and tried my parking brake that didn't hold either, needless to say I found a different parking spot.
Old 01-15-2009, 08:20 AM
Believer45 Believer45 is offline
Compression in the engine is what actually holds the truck back when parked in gear. Compression in the cylinders leaks past the piston rings slowly (it is not a 100% seal) so the holding power of the cylinder or cylinders that is holding the truck at a specific spot leaks off. When it gets low enough the truck moves until it gets to the next holding point (compression built up in another cylinder) which stops the truck until that cylinder leaks compression down and it goes again until the next holding point - and so on.
Dave / Believer45
'95 F250 power stroke 5 spd 4x2, extended cab, long bed, 3:55 rears, open air filter, 285/75x16 Cooper ATR tires, LUK single mass flywheel conversion, Putco master boss running boards, aluminum cap on bed, custom rear bumper (@450 lbs), scale weight full of fuel, me in it (285#) - steer 3420 lbs drive 3160 lbs gvw 6580 lbs, 280,000 miles as of Feb '09
Also 1996 Chevy Cavalier 2.2 auto 4 door LS, 95,000 miles.
Old 01-15-2009, 01:14 PM
dfordski's Avatar
So the moral of the story is "Unless an opposing force greater than the force being applied (gravity) is introduced as a counteractive, your goin down (hill)! You saving all those sandbags for what.....a rainy day? Did you figure out which sandbag was the last one?
Old 01-18-2009, 05:23 PM
i just have the sand bags in their so i can get traction casue we had like 6 snow storms already and my tires are junk
Old 01-24-2009, 03:06 AM
dfordski's Avatar
aghhhhh!!!........sorry,just slipped out.
