Go Back   Automotive Forums Car Chat > Toyota > T100
Old 01-12-2009, 09:07 PM
dahirolla dahirolla is offline
Turn signal shorts entire electrical system!
Just a couple of days ago my truck started some weirdness. Using the turn signal sometimes causes all lights to blink, the radio presets to zero out and the engine to falter. Any ideas what to look for?
Old 01-13-2009, 09:41 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Turn signal shorts entire electrical system!
I'd find an electrical diagram and start checking the ground points for corrosion, wear, or short-circuiting between wires in a harness. Another possibility is a wire harness passing through a hole that has rubbed through the insulation, causing shorting. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-13-2009, 09:21 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Do you have wiring for a trailer hitch? that frequently causes all kinds of problems like yours.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
