blower motor failure
is it difficult to replace blower motor resister, for someone with mechanical knowledge?
Re: blower motor failure
Welcome to the forum!
As a general rule of thumb, please provide the details of your vehicle as they have changed significantly over the years. To address your particular question, we'll need to understand the model year and if you have the manual HVAC controls or the Electronic Automatic Temperature Controls (EATC). -Rod |
2000 Taurus / manual controls, with water seepage,and possible resistor damage ,apparently from a bad windshield seal. I did smell a carbon-like aroma thank you
Obviously you'll want to repair the source of the water before installing a new blower motor resistor. Also, check the level of the engine coolant to make sure the liquid isn't coolant from a leaking heater core as well as making sure the drain for the evaporator is not plugged.
The blower motor resistor is not hard to get to, according to the service manual for the 2002 model year, which should be similar to your 2000: Blower Motor Resistor Removal and Installation
-Rod Last edited by shorod; 01-13-2009 at 01:33 PM. |
thank you
You need to check with your Ford dealer for the repair kit to stop the water leakage. If you don't the resistor and possibly the motor itself will go bad again. I have repaired these in the past, and it is pretty easy.
2000 ford Tauras ,Man. HVAC
thank you, Brown1911 was the repair kit part of recall for the windshield leak? Is it hard to check and/or unclog the evaporator drain? |
No it was not part of a recall. it is not the winshield leaking. It comes with a redesigned plastic piece that reroutes the water at the passenger side bottom of the winshield. I did not have to unclog evap drain.
