Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-12-2009, 01:04 PM
mdgoebel mdgoebel is offline
2006 4x4 3/4 ton 4x4 issue
I was stuck in snow/slush on a lake this weekend. In 4 wheel drive only my front passenger side and rear driver side tire would spin. This does not seem normal to me. Any ideas?
Thanks
Old 01-12-2009, 01:54 PM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
Re: 2006 4x4 3/4 ton 4x4 issue
Front ends are NOT limited slip and one wheel will spin if no traction. If you have rear limited slip it is controled by clutches and will do the same thing under more extreme conditions. If the rear is not LSD then it is also normal
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
Old 01-12-2009, 03:59 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Limited slip differentials and locking differentials are available at most 4x4 and speed shops.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
