Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 01-12-2009, 11:02 AM
88silveradoRWD 88silveradoRWD is offline
Amp light and rear ABS dash lights on
92 Fullsize Bronco has amp light on continually, seems to start and run fine, even in below zero temp. voltmeter jumps around sometimes when lights or blower motor is on, but returns to normal area on gauge. could this be a bad voltage regulator or alternator problem? Also occasionally the rear ABS light comes on then goes out, does this sound like a axle sensor or wiring problem? Any info will gretly help.
Old 01-13-2009, 11:03 AM
wafrederick wafrederick is offline
Banned
Re: Amp light and rear ABS dash lights on
Disconnect the ABS and leave it that way.Ford had lots of problems with this ABS system.Your brakes will work better with the ABS disconnected.
Old 01-13-2009, 11:39 PM
ok how would i go about doing so, at the master cylinder or removing a fuse ? Not sure
