| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
AWD or FWD with 4G63T
Ok, my previous post asked a question which i learned through little research online. Now asking if anyone posts a reply is whats better AWD or FWD with a 4G63T motor. I have a 93 eclipse GS which is FWD. Options.... Swap powertrain in current car; search for a cheap GSX and part current car out; or run my GS FWD with a 4G63T motor.
Thoughts and Opinions much appreciated. |
Re: AWD or FWD with 4G63T
What are your goals?
Kris 2012 Genesis Coupe 2.0t |
Just so you realize, the 4g63t is the turbo version to your 4g63. The internals to the two motors are different. It would be pointless to add AWD to your GS which is way underpowered. You could end up trying to swap a 4g63t and AWD into your GS but it would be entirely more work and money than its worth. If you really want AWD and a lot more power, ditch the GS and just start out with a GSX or TSi AWD. You'll spend a lot less time and money going that route than doing any swapping.
-Brian
yea I agree with brian here.
The engine isn't going to put out enough power without a turbo to make it necessitate awd on the other hand the fwd to awd is very time consuming and difficult. If you want it all its best to start with as much as you can get.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Well i was thinking i would get an engine stand, buy a jdm 4g63t motor build it up with bolt ons and all the other jazz. Then when i was ready put it in the car. I am just curious whether the pro's about having an AWD out weigh that of just a FWD. Would it be worth the headache. I think ultimately my goal is to get from say.... 0 - 90 really damn fast.
the pro's of awd outweigh the fwd by far
I agree with everyone on here, you will want to start with a turbo car, whether or not you choose to go FWD or AWD. You will want to just sell your GS or part it out, however you can get more money for it. OR just keep it as a daily driver as you will probably need it for when your turbo car is not running while you work on it.
I definitely say that AWD is much better than FWD. I really dont see any point in building a high power FWD car.
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
