Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-11-2009, 07:08 PM
Dave_s Dave_s is offline
Synthetic oil
I have an 06 impala and I'm thinking about switching to synthetic oil. Has anyone tried this? Does it increase gas mileage?
Old 01-11-2009, 07:18 PM
maxwedge maxwedge is offline
A990 racer
Re: Synthetic oil
You may some some very slight improvement, it does make for better starting in cold weather and less engine wear.
Old 01-16-2009, 12:51 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: Synthetic oil
I use it and like it. I can go 5000 miles between oil changes instead of the recommended 3000. A bit pricy, another $20-25 per change if I have a shop do it.
Bob
Old 01-16-2009, 01:22 PM
j cAT j cAT is offline
Re: Synthetic oil
I would try the synthetic engine oil. before you change to synthetic get a good MPG calculation...then after 300mi.on the synthetic start cal. of the MPG...I would say 1-2 mpg increase,also in very cold weather faster crank and smoother cold idle...you may also notice the vehicle will coast farther when taking your foot off the throttle...
changing the oil at 8,ooomi is safe...thats my interval...so you end up paying about the same except you save on fuel/engine wear...with synthetic..I use mobil 1..at costco it is 35.oo/6pack....2x conventoinal oil cost.
If you do this report what you found good/bad..
Old 01-16-2009, 03:12 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Synthetic oil
I'm surprised you guys don't lengthen the interval you keep the synthetic oil in your engine. I use Mobil 1 and keep it in 12,000 miles/1 year. About halfway through this time period i change just the filter and top off the oil level to compensate for any loss due to the filter change. My oil still is clean towards the end of the cycle.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 01-17-2009, 07:01 AM
jonnik jonnik is offline
Re: Synthetic oil
I've been running Amzoil in my Malibu for 100,000 miles, changing the filter every 5,000 miles and the oil every 20,000 miles. The engine burns no oil and gives me 30+ MPG. I'm sold!
Old 01-17-2009, 11:49 AM
Re: Synthetic oil
I replace at 8,000mi.. but my co-worker replaces the oil on his honda every 20,ooomi, and the filter at 5,ooomi...he has 200,ooomi on the engine with no problems....synthetic is the superior product...
Old 01-17-2009, 11:55 AM
Blue Bowtie's Avatar
Registered Offender
Re: Synthetic oil
Originally Posted by j cAT
..I use mobil 1..at costco it is 35.oo/6pack....2x conventoinal oil cost...
The Wal-Berg in my area sells M1 in 5-quart jugs for about $23 (It must be an exclusive marketing agreement, since no one but Wal-Mart has 5-quart jugs). I shop there once or twice a year just to buy about 5-6 jugs, and try to get out ASAP.
Old 01-17-2009, 03:18 PM
Re: Synthetic oil
In my area, I noticed last year Mobil 1 was selling for $26 a 5 qt. container. Then Wal Mart came out with their own brand of synthetic in a 5 qt blue bottle for $16.99. Then I noticed the Mobil 1 reduced it's price to $19.99. Now it's selling for about $23-$24. I use the Wal Mart synthetic in my small engines.
Old 01-17-2009, 05:58 PM
jrecken jrecken is offline
Re: Synthetic oil
I currently use Shell Rotella synthetic in my truck and motorcycles and dino oil in both cars. My next oil change I plan on using the Wal Mart synthetic to give it a try. I have been using the Super Tech dino oil with very good results. I am glad to see that someone else uses the Wal Mart synthetic.
Old 01-17-2009, 07:11 PM
Re: Synthetic oil
I just had my oil changed. I'm going to wait for the next scheduled to switch to synthetic. Its cold up here (CT) so anything that will start / run better in the cold is worth the cost.
Old 01-17-2009, 11:03 PM
YYeahoo YYeahoo is offline
Re: Synthetic oil
Dave I don't know which Synthetic Brands are the best. However I believe in synthetic oil. Eight years ago I bought a 94 GrandAm with 139000 miles for my daughter and the previous owner had used Quaker State full synthetic. But like many GM 3.1L it had a Intake manifold coolent leak. When I tore into it it was the cleanest old engine I had ever seen. It is still going strong today with over 213000 miles. Since then I have switched all my vehicles to Synthetic and only change oil 5,000 to 7,000 miles. My work car is a 96 Monte Carlo and it has 198000 plus miles... Tranny is tired but engine runs like a charm. I'm a believer...
YYeahoo
Old 01-19-2009, 10:24 PM
Mail Clerk Mail Clerk is offline
Re: Synthetic oil
Dave_s,
Just passing through and noticed your question. Both my truck and car is currently using Mobil 1 and have been using it since it was introduced and can be bought from my area.
In my opinion synthetic stays cleaner longer so just for that I'm a hard core user to begin with. Assuming the manual wants you to use 5W-30 weight oil I'd stay with that grade/weight. Many brands are available in that weight so chose the brand you can afford reasonable. My area has Quaker State "Q" synthetic for slightly less than my M1. I've tried this oil and found it to be a fine oil to boot.
If you in it for the gas mileage then I can't say much cuz my thinking is it's all in how heavy the gas pedal is. For myself I'm in it for the engine longvity and superior lube qualities.
If your not sure then it doesn't hurt to try it a couple times and see. Continue to change your oil as prescribed.
Mail Clerk
Old 01-22-2009, 08:00 AM
bobl99 bobl99 is offline
Re: Synthetic oil
I have a 2006 Impala and started using full synthetic (Pennsoil) about a year ago and checked the mailage on a long trip and it improved about 1-2 miles per gallon. I agree with the other posts on longer terms between changing and less wear and tear.
Old 02-11-2009, 11:35 PM
Re: Synthetic oil
bobl99,
Personally I don't agree with longer than prescribed oil changes because it does no good IF the oil filter hasn't the capacity to go a longer stretch. I can only suggest if a larger filter can be adapted. Many filter can be.
Mail Clerk
