Go Back   Automotive Forums Car Chat > Toyota > Tundra
Old 01-11-2009, 11:00 AM
sivad1016 sivad1016 is offline
Unhappy timing belt shredded
01 v6 shredded timing belt. Am i wasting my time trying to fix this? Any hints on getting the crankshaft pulley off? I can't seem to get anything to wedge in the crankshaft as chilton manual suggests.
looking for a little experienced help.
Jeff
Jeff Davis
Old 01-13-2009, 12:20 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: timing belt shredded
The simplest way, though kind of hesitant to use, is to use a large breaker bar and socket, wedge it against a solid piece of the truck. Then disconnect the ignition system or remove all the spark plug wires from the plugs and "bump" the starter with the ignition key. The engine starter should have enough torque to loosen the pulley bolt.
An optional method would be to wedge a screwdriver into the flywheel plate (you'll have to remove the cover)...this could be used to retorque the pulley bolt when you're done. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-20-2009, 08:27 AM
Thanks for ther tip...I ended up buying a piece of 24"x4"x1/8th" steel at Ace Hardware and drilling two holes that line up with the crankshaft pulley holes and a larger one that the 19mm socket would fit through and then added about a 18" cheater bar to my breaker bar and was able to break it loose. I used two phillips screw drivers to hold the tool next to the pulley and the steel was long enough to reach the frame and created the stability needed to remove that bolt.
Ended up replacing the upper and lower pulley as well as the water pump. All 3 pulleys were frozen. Once the crankshaft bolt was removed the job was not too tough. I also had to replace the crankshaft sprocket gear because I broke off several of the teeth trying to lodge a crowbar in order to remove the brankshaft bolt (doesn't work, don't try it, it only adds about $53 more to the job).
I was pleased that the 3.4 v6 is a non-interference engine and no damage was done to the heads, pistons or rods.
Total cost was about $350 in parts.
Jeff
Jeff Davis
Old 01-25-2009, 11:40 PM
Puffnstuff's Avatar
Puffnstuff Puffnstuff is offline
Send a message via ICQ to Puffnstuff
It makes me wonder why the v6 is noninterference but the v8 isn't. I really wish the v8 had a double chain instead of the belt.
06 Toyota Tundra Double Cab
Old 01-26-2009, 10:50 PM
jdmccright's Avatar
The RustBuster
Putting a timing belt on any V8 is just plain stupid to me....into a truck is maniacal.
BTW, sivad, nice job making your own spanner wrench.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
