Old 01-11-2009, 09:10 AM
superbrad69 superbrad69 is offline
95 Cavalier Transmission engage problems
When the car is put into gear (reverse or forward) you press the gas and it will act as if in neutral, then a second or two later will engage and slowly go. Eventually it will even shift gears while driving. Every stop I come to it starts over. Checked the fluid and it needs to be changed but what else might it be? I don't want to replace a tranny.
Old 01-28-2009, 07:25 PM
demo_deven's Avatar
demo_deven demo_deven is offline
Send a message via MSN to demo_deven
Re: 95 Cavalier Transmission engage problems
I know you said that it does this at every stop but does it do it mostly when it is cold and gets better when it's warm? I'd get a trandmission flush and change the filter. Try some Lucas with the new fluid as well. Stuff works miracles!
"If it runs and moves, DERBY THE DAMN THING!"
- 2000 Ford F-150 4.2L V6 Reg. Cab Long Box 223k. Nothing special, just a beater work truck.
- 1995 Ford F-250 7.3L PSD 2WD 291k. K&N Air Intake, 4" Turbo-Back to 5" Staks through the box. Other then that a good truck for pulling around my toys!
www.SmashCarRacing.com
1997 Pontiac Sunfire
