Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-10-2009, 09:42 PM
keith32 keith32 is offline
Unhappy chirping noise from engine
I have a 2000 suburban, 5.3L. On cold days I get a chirping noise coming the engine when running or a pulley. I have replaced the a/c belt, and idler pulleys. I am thinking it may be the alternator, but have had no symptoms to indicate it. It doesn't do it if the temperature is above 45F. Has anyone had similiar issues? thanks
Old 01-12-2009, 09:07 AM
j cAT j cAT is offline
Re: chirping noise from engine
I have had this occur since 2000..the upper idler pully bearing was causing this on the main drive belt..I put some lube at the bearing a couple of drops 20wt oil and it stops for a long time...
what is also common in cold damp weather is belt squeal...as the belt makes noise until the mositure is gone usually a few seconds.
