Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-10-2009, 09:03 PM
eccs19 eccs19 is offline
99 Regal GS Coolant leak
My Regal is now leaking coolant from the lower intake. Shop said between $1000-$1500 to do, depending on what's found during the procedure. I'm fairly mechanically inclined, and have done work on cars before. (mostly older, non computerized cars) Is this something that I can do myself? Any good links for my reading? It's not leaking badly yet. I have to top the coolant up every month or two. Oils gone milky, but oil is still clean, so I think (and the mechanic) it's still in the early stages.
Thanks in advance.
Old 01-11-2009, 08:52 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 99 Regal GS Coolant leak
Where exactly is the leak? Any pics or can you better describe where it is leaking?
Doing the LIM gaskets on a L67 SII 3800 engine is a DIY job. Just tedious if it is your first time. The procedure is the same as the N/A SII 3800 engine except you substitute removal of the Eaton M90 supercharger versus the plastic UIM plenum found on the N/A engine. Be sure to get good quality supercharger and LIM gaskets and follow the proper torquing procedure for all SC and LIM bolts.
Timeslip 08/12/06
AF Community Guidelines
Old 01-11-2009, 12:04 PM
Thanks for the response.
Leak is on the front of the engine (front of car, not engine itself). It is around the middle cylinder.
Do you have a recommendation for a good replacement set of gaskets? Any good online reading on how to do it? I found a couple of similar issues with links on the forum, but the links were dead.
Thanks again.
Old 01-11-2009, 05:53 PM
BNaylor's Avatar
You're welcome.
You can get the new style GM aluminum framed LIM gaskets at the following link along with the throttle body and supercharger gaskets. Also, be sure to get two new coolant bypass elbows for the tensioner assembly. Just send me a PM message with your regular email address and I'll send you what I have since those links are not working.
ZZPerformance
Timeslip 08/12/06
