Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-10-2009, 02:54 PM
chaswe75 chaswe75 is offline
EGR P0401 That will not go away
I have this DTC P0401 that continues to plague my '96 3.2L Rodeo that will not go away. I replaced the EGR since it had such a build up of carbon that cleaning would not be practical. I also have two new cats and pre-cat O2 sensors since they were popping codes and the truck has 162k on it. I cleaned out all passages including the pipe to the exhaust manifold. I pulled the throttle body and don't see a pipe running through the plenum and intake manifold. I checked the FAQs and only see some info on how to clean '98-on motors and still can't determine if it has the same setup or not. I know those motors are a bit different. If I pull the EGR off then start the motor, the RPMs shoot up rapidly, leading me to believe it is not clogged. The EGR is an aftermarket Delphi and I continue to read how these Rodeos prefer factory parts. My next step is to try and get a factory EGR and see if this will remedy the problem. Any suggestions??
Old 01-10-2009, 08:08 PM
Cat Fuzz Cat Fuzz is offline
Re: EGR P0401 That will not go away
Delphi IS factory. You've still got some sort of blockage somewhere. You may have to remove the throttle body to completely trace the entire path of the EGR system.
Your blockage is most likely between the EGR and the intake. Usually right where the passage exits into the intake or throttle body.
Old 01-10-2009, 10:13 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Try to shoot some compressed air down the pipes.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-10-2009, 11:19 PM
Ramblin Fever Ramblin Fever is offline
What happens if one just leaves it alone??
Seriously...I have the same issue that's been on going for quite some time. I flat gave up, Rodeo still runs just as good. But...will it hurt it in the long run?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 01-11-2009, 02:55 PM
Actually, it could cause damage in the long term, although unlikely, as well as making the engine run less efficiently by causing the timing to be retarded when the PCM detects more frequent spark knock. Also, if he has to pass an emissions test where he lives, the car won't pass.
The EGR system is actually very simple. It is simply a passage from the exhaust back to the intake. The passage is controlled by the EGR valve which is controlled by the PCM. When the PCM commands the valve to open, it expects to see a change in the O2 sensor readings. If it doesn't see that change, it can only assume that the EGR passage is blocked or the valve isn't working. EGR is just a very easy way to reduce NOX emissions which is caused by high combustion chamber temps. The recirculated exhaust gas lowers the combustion chamber temps keeping NOX in control and helping control pre-detonation or spark knock.
Old 01-12-2009, 12:31 AM
So...is it unlikely?
I don't know where else to look, honestly. I've cleaned the tube out as much as I could, replaced the valve, etc. the code still comes back.
CEL goes on and off quite often, always the same code.
1997 3.2L V6 Rodeo
Old 01-12-2009, 11:29 AM
That is what I thought. Delphi produces for Isuzu and GM. One suggestion from a mechanic was to pull the EGR off, start the engine, wait and see if the RPMs shoot up rapidly. He claims that if they do, then there is possibly other causes. After searching the FAQs on cleaning the passages, I can only find '98- motors. I've pulled the throttle body and don't see a pipe running through the plenum like you do on the newer models. Is there a tube that runs through the intake man. on this year? Damn these engines are messy. The truck runs like a beast though.
Old 01-12-2009, 11:33 AM
Have you pulled the intake off and cleaned in there or looked for an extension of the piping?
Old 01-12-2009, 05:28 PM
matandnat3 matandnat3 is offline
Is it necessary to disconnect the neg. cable for 15min and put back on in order to reset the onboard diagnostics? Did you do that?
Old 01-12-2009, 08:51 PM
Matan**,clear the code??? Come on buddy, looking for some realistic diagnosis.
Old 01-13-2009, 08:05 AM
No, I haven't pulled the intake, for one, everything I've read says that it won't do serious damage and the fact that it runs so good otherwise, I haven't seen the real need to do so.
But..if it does cause damage, then I'll look into it. I've meticulously maintained this beast, and out of everything I've read, everyone's been able to clear this code without taking off the intake.
1997 3.2L V6 Rodeo
Old 01-13-2009, 05:29 PM
wreck05's Avatar
wreck05 wreck05 is offline
I had this problem too. What solved the problem for me was to take the EGR off -- spray carb cleaner down the passages and then start the engine. The gunk and carb cleaner will expel (you may seem some flame -- stand back!). Clean everything again and replace EGR.
2001 Rodeo LS 2WD 3.2L
"When you step on the brakes -- your life is in your foot's hands!"
Old 01-14-2009, 09:42 PM
Wreck,
I've tried cleaning everything(passages to the throttle body and tube running to the exhaust manifold). No luck, the code keeps coming back.
Old 01-14-2009, 09:52 PM
I am getting a P0440 code now along with the P0401. I can see from the schematics that the EVAP canister vent solenoid and EVAP canister purge solenoid are related to the EGR in terms of vacuum lines and/ or system. Is there a connection here? Leak in the canister/line or vacuum leak.
Old 01-15-2009, 05:24 PM
wreck05's Avatar
Wreck,
I may not have explained it very well. What was happening to me was I would get the EGR cleaned out very well with carb cleaner. I would then clean out the actual passages. When I would replace the EGR and start the engine -- the carbon build-up that I attempted to clean would re-foul the EGR valve and thus defeat the original cleaning. I'm saying to let the motor rev (with the EGR off) for awhile to let the passages clear up. THEN, clean the EGR valve itself again (and around the gasket). Replace the EGR, unhook the negative battery cable for 15 minues before re-starting again. You should see enhanced engine performance and no return of the code.
