Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 01-10-2009, 11:12 AM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Long to warm up
When I drive my Accent 95 (1.5L) in the city, it take me 3 miles to let my engine reach its normal temperature. It is normal?
I live in North where temperature is 0°F. I don't let engine warm up more than 30s before driving, to avoid pollution.
Also the coolant temperature gauge needle is at 1/4, after the "Cold" marker. It is normal? Or it should be more?
Also, heater is not very warm. It can be my thermostat that is always open?
I need your help.
Old 01-15-2009, 11:14 AM
Re: Long to warm up
I need to change my thermostat or not?
Old 01-31-2009, 11:21 PM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Re: Long to warm up
Try having a hotter thermostat installed (192 degree F) you might have the 180 degree F installed. Believe me 12 degrees makes a huge difference in heat.
Old 03-12-2009, 10:15 PM
Re: Long to warm up
I have a 195°F thermostat and it's still long to warm up in cold weather (-9°F). And the thermostat is good.
I think that my car is not made for extreme cold.
Old 03-13-2009, 12:42 AM
Re: Long to warm up
well its about -5 here and my car (99 plymouth neon) heats up within about a mile and has good heat.
you might try blocking off some of your rad with something?
like what they do on dump trucks and school buses in the cold weather. little 4 bangers arent always the best as staying warm.
if you do make sure to keep an eye on the heat gauge and dont let it get too high.
you could try putting cardboard over a portion of your rad like say 1/4 and if that doesnt work maybe 1/2 at most.
also sometimes if you put the heat at the highest it doesnt always come out that warm. usually you have to leave it about 3/4 power to get good heat.
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
Old 04-12-2009, 09:22 PM
comunicate2u comunicate2u is offline
Re: Long to warm up
I have a new 2008 accent it is the same way; it takes a long time to heat up. I think it is just the way Hyundais are, or atleast accent I have freinds with a '02 and a '98 and they both say the same thing.
Old 04-12-2009, 09:40 PM
Re: Long to warm up
Yes, I think that small Korean cars are just not designed for extreme cold condition. It's because the engine head dissipates too much heat on the air and not enough heat in the coolant. So it warm slowly.
Also, their heater core are sooo small. The tier of a regular one.
I'm surprised that until now, they don't correct this problem.
But I've tried the trick of Godofwarmike, corcerning blocking the airflow on the radiator. It helps a little bit.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 06-15-2009, 07:44 AM
Re: Long to warm up
I had change my thermostat, it was not the problem. The car was definitely born to warm slowly. It'S not made for cold Country.
Now I don't have this car anymore. I was too tired of driving it.
