Old 01-10-2009, 09:12 AM
gweak gweak is offline
Automatically shift into 4 wheel low
I have a 2002 F150 that just recently had shifted into 4 wheel low while driving. After the engine was turned off, it was ok. I have not driven it since then. Any ideas? Could it just be a faulty switch? Any help would be appreciated.
Old 01-15-2009, 08:24 AM
Believer45 Believer45 is offline
Re: Automatically shift into 4 wheel low
When you say shifted into four-wheel low while driving do you mean actually went from high range to low range in the transfer case? If so there should have been clanging, clanking, engine revving up etc when it happened. If the truck did not actually go into 4 wheel low did the indicator in the dash show 4 wheel low?
I have never heard of this but then I am an old guy whose four-wheel-drives all have had manual transfer cases with two levers on the floor.
'95 F250 power stroke 5 spd 4x2, extended cab, long bed, 3:55 rears, open air filter, 285/75x16 Cooper ATR tires, LUK single mass flywheel conversion, Putco master boss running boards, aluminum cap on bed, custom rear bumper (@450 lbs), scale weight full of fuel, me in it (285#) - steer 3420 lbs drive 3160 lbs gvw 6580 lbs, 280,000 miles as of Feb '09
Also 1996 Chevy Cavalier 2.2 auto 4 door LS, 95,000 miles.
