Old 01-09-2009, 08:16 PM
family_mechanic family_mechanic is offline
97' loosing antifreeze
i have a 97' lumina and i have to add antifreeze every two or three days now. the oil looks good, and the antifreeze looks good(but i am adding to it all the time). i don't have any stains, or puddles under the car. there is a stain on the head but it looks old, and it looks like oil from the valve cover. has anyone else had this problem? any help would be great.
Old 01-09-2009, 10:39 PM
Forscythe87 Forscythe87 is offline
Re: 97' loosing antifreeze
I have the same problem. Its 90% likely the gaskets, althought its possible theres a pinhole leak in a hose and its burning off on the engine before it hits the ground.
1998 Chevy Lumina LS 3.1L 126K Miles
Old 01-10-2009, 03:29 AM
GreyZ34's Avatar
GreyZ34 GreyZ34 is offline
It could also be water slowly dripping out of the inspection hole on the water pump. When was it last replaced?
Old 01-10-2009, 08:28 AM
i've had the car 20k and i've never changed it. the car has 111k on it. when i drive the car and then park it i can smell antifreeze very strong outside the car.
Old 01-10-2009, 05:44 PM
GreyZ34's Avatar
could also be your heater core. smell it all in the car is the floor board warm and wet?
Old 01-10-2009, 06:03 PM
no i only smell it outside the car, and the floor is dry.
Old 01-10-2009, 06:54 PM
GreyZ34's Avatar
Id start the car block the tires car parking brake set and car in park and look under it to see if it is dripping out the inspection hole of your water pump.
Old 01-18-2009, 07:36 PM
well i found the problem. after about four days of adding water everyday i finally parked it and started taking it apart. problem 1; quick connect in the intake to the heater hose. problem 2; both intake gaskets were falling apart near #5, and 6 cylinders. the intake, and valve covers are on, but its hard to work in the dark.
