Old 01-09-2009, 06:50 PM
fishincrazzy fishincrazzy is offline
Brake Problems
I have replaced rotors,drums, pads, shoes. I have ran 2 quarts of brake fluid thru system, old fluid has a yellow color to it. Master cylinder has a green slime in it which is problably causing the yellow color. When I bleed the system all is good for a day or two then ther is a bad vibration in LF and RR. Do you think I need to replace the master cylinder to fix this problem? Could it be ABS sensor? Open to any ideas.
Old 01-11-2009, 04:46 AM
dfordski's Avatar
dfordski dfordski is offline
Re: Brake Problems
Are you loosing brake fluid?
Old 01-11-2009, 10:40 PM
Davescort97 Davescort97 is offline
Escort guy
Re: Brake Problems
LF and RR operate off the same line into the master cylinder. I think with the green slime you would do well to replace the master cylinder.
Old 01-12-2009, 04:33 AM
dfordski's Avatar
Re: Brake Problems
If Your establishing new life forms, besides being particle contaminated, your running w/ a high moisture content. Remember science class? H2O @ 212F = Vapor! You might luck out on the master but their not that much $. You don't seem like you want to deal w/ your brake system alot, so do yourself a favor & switch to synthetic Fluid, because Your RABS valve is next & that's when the fun really starts. Synthetic might buy you some more time.
