Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-09-2009, 01:09 PM
dapopes's Avatar
dapopes dapopes is offline
95 gm volt meter
The volt meter on my 95 GM runs pretty high all the time, and occasionally i can see a "fluder" in the headlights when stopping at stop sign and taking off again. The mechanic said I have too small of a battery in it (even though it's the one Wal-mart reccomends). could the size of the batt make alt work too hard? Meter only has "L" to "H". Needle stays close to "H". Thanks for any reply.
Old 01-09-2009, 05:55 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 95 gm volt meter
Is it a minimum of 850 Cold Cranking Amps? If it is running high on the gauge, check the voltage while it is running to confirm hi voltage or a bad gauge. It is possible the voltage regulator is on it's way out. It should be under 14.5 volts running. Usually from 13.5 to 14.2.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-10-2009, 04:17 AM
dapopes's Avatar
Thanks a lot for the quick reply WTO. That's a good idea to check the volts. I'll have parts store check it. Have a good weekend.
