Old 01-08-2009, 09:39 PM
|WYG|SS |WYG|SS is offline
weird grinding type noise in front end?
i got a 93 f150 4.9l 5spd 4x4. i am driving with the hubs locked ina dn on dry pavement i willl give it gas in first gear in 2wd and i hear a weird grinding type noise coming more from the drivers front end. i unlocked the hubs thinking that the 4x4 could be the problem. i unlocked them and it is still doing the same thing. any of you might now what this could be?
Old 01-09-2009, 12:36 AM
tempfixit tempfixit is offline
Re: weird grinding type noise in front end?
Have you checked the front wheel bearings?
Old 01-09-2009, 10:11 PM
i kind of explained it wrong. im going to check the bearings sometime soon. i have the hubs unlocked now. i have brand new motor mounts and trans. mount. there is snow on the ground now. i have bad tires. here is the new explination. i got the truck in first gear i give it gas and am spinning on the snow and when i hit the dry pavement the truck jerks and i hear a clicking noise. when i go around corners it will click more than it will do when i go straight. i sounst like i could be something to do with the suspension maybe.
( it sounds like a nut on a bolt and like your pulling the nut off the bolt right over the threads with out twisting the nut.)
Old 01-09-2009, 10:40 PM
With your new explaination I suspect it is the u joint on one of the axle shafts on the front end.
Go to this link: Online service manual, not perfect but is helpful.
http://www.oplin.org/databases/proxy...%2fframerq.asp
enter 123456789 for library card number, submit
there will be a library in the box, click on the box and more library's will appear submit the Public Library of Cinncinati
Scroll down to Auto Repair Reference Center, click on it
choose year, make, model, engine
Repair procedures
Go to drive train
You will find a picture of the housing, spindle and axle shaft along with repair procedures.
Your Local Library may also have this site.
Hope this helps
Old 01-10-2009, 12:59 PM
i also thought of that. my friend had that done in his 94 f150 and it only cost him 121.00.
