1999 Silverado Heater Blower not working
Fan was making a noise when first switched on then it would quiet down.
Now I have no Blower/Fan on any setting. Any suggestions what to try. |
Re: 1999 Silverado Heater Blower not working
Try a new blower motor...that screeching sound is the motor bearings giving up. Pretty simple. Also check that you're getting power to the blower...and check the blower fuse, since a seized motor will cause a high draw on that power circuit.
Good luck!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
let us know whats up...it could also be debris causing this...check that the cabin filter if so equipt is clean...... |
Under Passenger kickpanel is the blower and blower resistor which increases voltage to blower for high speed nad decreases for lower speed, seems its common for these to burn out causing no power to get to blower! Check for power going into resistor pack. If none and fuse is good its more than likely your HVAC cotroller.
