Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-08-2009, 05:20 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Hesitation
Can bad spark plug wires cause hesitation at low rpm (due to arcing) but not at high rpm? I found out that spark plug wires that use a graphite impregnated polymer to transfer the electricity tend to lose their performance after a while as they begin to arc at low rpms. And i also found out that GM uses (or used) these in their cars. So if anyone can back this up that would mean the end of my engine troubles because i'm almost positive these wires are original.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 01-08-2009, 05:24 PM
mgty3whlr mgty3whlr is offline
Re: Hesitation
Sounds like it may be a bad accelerator pump in the carb.
Old 01-08-2009, 05:38 PM
bhw33191's Avatar
Re: Hesitation
Thats probably unlikely cuz i had the carb rebuilt "the mechanic said it was in great condition to begin with too."
Old 01-08-2009, 06:40 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Hesitation
If accelerator pump is good, try checking the float level.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 01-10-2009, 10:13 AM
j cAT j cAT is offline
Re: Hesitation
I had a hesitation problem and what I did was disable the EGR...then the problem was gone...bought new EGR compared to old ..found that the EGR spring on old had less power...so it caused the engine to get too much NO...causing the hesitation....
with the EGR disabled the engine should ping slightly...
