Old 01-08-2009, 04:27 PM
krash421's Avatar
krash421 krash421 is offline
Exclamation 98 PAU Multi function switch removal?
I have a 1998 Buick Park Avenue Ultra and need to know how to remove the turn signal/Wiper/Cruise control multi switch. Thank you and please be as detailed as possible...
Old 02-04-2009, 02:49 PM
krash421's Avatar
Re: 98 PAU Multi function switch removal?
Does anyone know how to remove the multi-function switch. Everything for the speed of the wipers work except for the washer fluid control and the cruise control sometimes doesnt work or it will turn off while i am using it, without me turning it off, or touching the brake pedal?
Old 02-04-2009, 06:25 PM
krash421's Avatar
Need tech procedure with pics for 98 PAU
I need to know how to take the turn signal switch out of my 1998 Park Avenue Ultra. Do I need to remove the steering wheel, because I am really hoping that I dont because I do not have a GM steering wheel puller and the one that AutoZone has supposedly does not work for my vehicle. Please attach tech procedure with pics if they are available. Thanks for any and all help
Old 02-04-2009, 07:43 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Need tech procedure with pics for 98 PAU
Your new post about needing a tech procedure for the multifunction switch MFS has been merged with the prior recent post which is based on the same issue.
I'm not sure about your year and model PA but many GM cars do not need to have the steering wheel pulled to replace the MFS. The factory service manual would be the best reference or hopefully a member that has done it weighs-in. If a steering wheel puller is needed you should use the one recommended by GM in the FSM.
Timeslip 08/12/06
AF Community Guidelines
