Old 01-07-2009, 01:10 PM
sboaterdude sboaterdude is offline
88 7.4L TBI loss of power issue
I have a 1988 chevy 1 ton dually crew cab with dual tanks with just shy of 200K miles. I have started to have a driveability issue which is mainly loss of power. The truck will start and idle fine, but as rpms come up, power goes bye bye.
I have replaced plugs, wires, cap and rotor. I have replaced ignition module and coil. I don't think it is fuel pump as the truck has dual tanks and each tank has its own pump and I doubt both would go bad at the same time. I have tried new ECM.
I do have a scan tool and the truck is not showing any codes.
Any suggestions are appreciated.
Old 01-07-2009, 02:51 PM
maxwedge maxwedge is offline
A990 racer
Re: 88 7.4L TBI loss of power issue
Try disconnecting the cat see what happens, also new fuel filters? This is not a misfire but it just lacks power? Make sure both TB injectors are working, also.
Old 01-07-2009, 05:13 PM
I also did a new fuel filter. There is only one which is after the swith over valve.
It doesn't seem to be a miss as it idles very smooth. It moves and will accelerate if you take it easy, but when you get deeper in the throttle, it stops accelerating and bogs down.
Old 01-07-2009, 06:59 PM
A990 racer
Pull the exhuast down from the manifold if you can.
Old 01-07-2009, 07:31 PM
777stickman 777stickman is offline
Another indication of a plugged CAT, or a resticted exhaust sytem, is an increase in engine coolant temp when it's bogging down trying to accelerate.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
