Old 01-06-2009, 10:04 PM
pontiackid66 pontiackid66 is offline
removing crank?
i have my engine(2.3 liter quad4 sohc) on an engine stand and im in the process of removing the crank. im trying to remove the pulley attached to the crank and appariantly the previous owner has done this before and put the pulley on with like 300lb of force or there is some kind trick i dont kow of. Is there any kind of special technique or tool i need to remove this pulley so i can then remove the time gear etc. to get to the crank? thanks any help will be much appreciated.
Old 01-07-2009, 10:17 AM
3100 3100 is offline
Banned
Re: removing crank?
crankshaft pulley removal tool
Old 01-07-2009, 04:12 PM
Re: removing crank?
oh ok umm what i was trying to say was i cant get the bolt off the pulley to remove the pulley because i have a pulley puller. but i need to remove the bolt that holds it on there and right now im just using the biggest breaker bar i have a a socket that fits. is there something that could make it easier? because like i said its on there with like 300 ft-lbs of torque.
Old 01-07-2009, 04:21 PM
Scrapper Scrapper is offline
AF Premium User
Re: removing crank?
you need a good air impack they are tight. i don't know if auto zone rents them out but you could give them a call them because they rent them tools out.
Old 01-07-2009, 04:49 PM
Banned
Re: removing crank?
breaker bar should do it and you can even put the pipe extension on the handle of your breakerbar so you have more force and just jam the flywheel good
Old 01-07-2009, 05:37 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: removing crank?
They sell/rent a chain tool that wraps around the crank pulley and holds it while you loosen the bolt. Anyother means of holding the pulley could damage it.
The bolt should be torqued to around 180 FT Lbs.
1999 Grand Am SS 3.4 OHV
Old 01-07-2009, 07:26 PM
brcidd's Avatar
brcidd brcidd is offline
Re: removing crank?
Easiest way is to put the breaker bar on it- and push it up against the frame, or floor or something solid- and hit the starter (turn ignition switch to start) for a half second- works every time....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 01-07-2009, 10:45 PM
Re: removing crank?
yeah brcidd, the OP said engine is on a stand already.
Old 01-08-2009, 12:10 AM
Re: removing crank?
well i finally got it off. i put my other breaker bar in a whole in the flywheel, willing to sacrifice it, and broke it free and got the bolt and pulley off. now theres a bracket below it with three bolts in it attached to the timing chain cover giving me the same anount of difficulty and im starting to strip it. haha any hints? im at a loss
Old 01-09-2009, 11:21 PM
Banned
Re: removing crank?
clean bolt heads and sockets or wrenches with brake cleaner to avoid striping their heads.
