Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-06-2009, 04:23 PM
Rbal94 Rbal94 is offline
EVAP Canister Vent Solenoid
I have a 1998 Rodeo 3.2 dohc v-6, Can anyone tell me if the Evap canister vent solenoid mounted on the rear of the vehicle above the spare tire, ( NOT THE PURGE SOLENOID mounted on the intake manifold) is a normally open or a normally closed solenoid. I have the solenoid in hand off fo the vehicle and I am able to pass air thru it. Thanks
Old 01-09-2009, 08:33 PM
okmech1 okmech1 is offline
Re: EVAP Canister Vent Solenoid
This is a wierd system to figure out, at least by reading the factory manual. I have a 2001, assuming it is the same, the Fuel and Emissions manual somewhat contradicts itself, but after reading the description several times, I believe it is normally open:
"EVAP Canister Vent Solenoid. Located next to the canister, the vent solonoid opens to allow air into the EVAP system. Fresh air is necessary to completely remove gasoline fumes from the canister during purge. The EVAP vent solenoid closes to seal off the evaporative emmissions system for leak testing"
notice the underlined section - I read it as, if it closes, it needs to be actuated that way, so normally open.
What's your problem anyway?
2001 Honda Passport 3.2L V6, all stock - 90K
2009 Toyota Matrix - 10K
Old 01-11-2009, 09:45 AM
I have logged a P0440 code and I had the truck smoke tested and smoke was leaking out of the vent located next to the vsv. I removed the solenoid and I can pass air through it. I was just wondering if that is normal. The coil does not have a break in it so I assumed the valve should be normally open. Your reply pretty much confirms that it is normally open.
Thank you very much for your reply
Old 01-11-2009, 05:57 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Can you can "pass air thru it" with the coil energized, un-energized, or both? If both it's bad.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-17-2009, 07:57 PM
I only have 4.5 volts to this solenoid, what is the normal voltage to this solenoid?
