Old 01-06-2009, 03:45 PM
chefmaq chefmaq is offline
92chevy lumina stalls
i have a 92 chevy lumina 3.1 v6 auto trans. 199,306mi. the car starts and runs rough it will let me drive about 1 mile and then it starts to stall at every stop sometimes if i ride the brake and gas i can keep it runnig.but it still sputters chokes and backfires. i have replaced the egr valve map sensor ,engine coolent temp sensor vacum harness and hoses. i just tried a new iac valve and it still did the same.kno i am begging for the right solution.please
ty mike
Old 01-06-2009, 05:51 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 92chevy lumina stalls
You have actually posted in the Chevette forum. For a moment, I got all excited because I thought someone out there actually still drives one
Your trouble could be explained by bad plug wires.
When the insulation breaks down on the spark plug wires, the spark energy can jump to ground or jump to an adjacent plug wire, causing weak, erratic and improperly-timed sparks.
Also, a worn timing chain, or one that has jumped a tooth can also cause this trouble.
Old 01-07-2009, 07:43 PM
mgty3whlr mgty3whlr is offline
ty mike
Bad fuel injector(s) they were common! Big time
A high resistance in the injector will cause the rough running and stalling.
being that 3 of the injectors run from one driver and the other 3 run from the other driver.
what happens is the high resistance in one or more injectors will feed back to the computer and cause the other injectors not to fire properly causing this condition.
The unfortunate thing is that you have to remove the upper intake plenumn to access the injector to measure the resistance.
remove all of the injector connectors and measure the resistance of each injector.
anything under 12 ohms, the injector is bad.
