oil leak problem
i have 2000 chev blazer 4x4 and was told it is leaking oil from the oil pan gasket and they want $800.00 to fix it. wow!!!!! has anyone had problems with oil leaks with a 2000 chev blazer. do have to pull the eng. to replace it.
Re: oil leak problem
Common areas for leaks are the oil pan, oil lines, crank position sensor, lower intake, and rear main seal so check all of those. To do the oil pan the entire front axle has to come out and the engine has to be raised about 2 inches. If its a rear main, the trans has to come out.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
