Old 01-03-2009, 12:50 PM
blueraven76 blueraven76 is offline
Re: Headlight Fix
I have a 2001 GLS Intrigue and I can't find the fuse for the Daytime running lights. Does anyone know where it could be? Also, if I unplug the sensor, would that disable those lights?
Old 01-06-2009, 02:52 PM
carbon02 carbon02 is offline
Re: Daytime Running Lights
There are two fuse boxes on the intrigue. Check the one on the passenger side of the dash, as you open the door, and also check the black box directly above the battery mounted to the passenger strut support under the hood.
Everything should be labeled, and hopefully you can find it there.
2002 Oldsmobile Intrigue, 3.5L, GX --121,000 Miles as of 2/4/2011
2000 Oldsmobile Intrigue, 3.5L, GX --81,000 Miles sitting in garage awaiting shift kit P1811, and potential water crossover gasket repair.
Old 01-06-2009, 04:30 PM
harmankardon35 harmankardon35 is offline
DRL fuse is on the passengers side of the dash when you open the door. I pulled it on my 98' to avoid melting light bulbs
