Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-06-2009, 08:20 AM
jtmarten jtmarten is offline
Considering a cat-back
I'm considering having a cat-back installed on my '96 K2500 w/454. If I do, I'll be going with a dual in/dual out muffler, with the tips exiting under the bumper. The shop I'll have do it will fab up the system, let me hear it to make sure its not too loud/too tame, etc before welding it up.
They tell me I should see an improvement in mileage, but not much of an increase in power - true/false??
I don't really want to lay out $400+ just to get a nice rumble.
Thanks!!!
Jeff
Old 01-06-2009, 10:18 AM
j cAT j cAT is offline
Re: Considering a cat-back
Originally Posted by jtmarten
I'm considering having a cat-back installed on my '96 K2500, 454, 4.10 gears. If I do, I'll be going with a dual in/dual out muffler, with the tips exiting under the bumper. The shop I'll have do it will fab up the system, let me hear it to make sure its not too loud/too tame, etc before welding it up.
Thanks!!!
Jeff
you will not see any MPG improvement...
If you tow very large loads you may notice more power....and the engine will run cooler...
if you do not do heavy hauling this will not do anything..as your vehicle had when built a good exhaust match..
Old 01-06-2009, 10:24 AM
Thanks for the info!
I currently pull a 4300lb boat, but am looking at larger boats in the7000-8000lb range. Looks like it may be beneficial to have, but I may wait on it.
Old 01-06-2009, 10:56 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Your rig as optioned should easily tow 8k with weight-dist hitch, brake controller, and HD trailering options.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-06-2009, 08:07 PM
Elbert Elbert is offline
Assuming you have the stock OEM muffler now.... No just changing to a new muffler will not add any real power. Might make it sound good. I have a magnaflow dual in dual out.... sounds good under acceleration....not so loud at cruise speed... 92K1500 5.7..
Elbert Clarke
