Old 01-06-2009, 02:10 AM
tleeburks tleeburks is offline
94 c1500 silverado won't start consistently
here is my story. i went out to the garage to start my truck. 94 chevy c1500 with about 185,000 miles. turned the key and got nothing. battery connections were fine, i even unhooked them and retightened them. still no start. so i took the wife's car to work. she called later and said she tried it and it started right up. so she takes it to work. back home, no problem. i get home and go to start it and it starts 3 straight times. then on the 4th, nothing. could it be the starter? i replaced it i believe about 3 years ago. im gonna take it up to autozone for a test today after work. any other clues? i could use the help. a week ago it wouldn't start, but that was the fuel pump, fixed it and it started until now. please help. thanks.
Old 01-06-2009, 11:06 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 94 c1500 silverado won't start consistently
There's been reports of the ignition switch going bad in the steering column...I'd check that too.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-07-2009, 07:11 PM
No luck on the ignition switch. just replaced it and it still does the same thing. ive cleaned off the connections to the battery (not really dirty) but thought i would. i just can't seem to narrow it down. i remember once when i installed a stereo it blew a fuse and i took it in (cost me 75.00 to check) and 2.00 for the fuse. which fuse would it be? anyone got any suggestions before i drag it to a mechanic? thanks
Old 01-07-2009, 09:38 PM
tempfixit tempfixit is offline
Have someone try starting it while you tap on the starter. Do you have 9.6 volts to starter with key in start postion?
Check the backup/neutral safety switch on the steering column. Do back up lights work?
Have you checked the wiring connections on the starter?
Old 01-09-2009, 03:34 PM
it was the ignition switch. thanks for the help, automotive forums saved me again.
Old 01-09-2009, 05:41 PM
How did you determine it was the ignition switch? In post #3 you mentioned that you installed ignition switch and did not work. Did you install yet another ignition switch.
Just curious, Glad you got it fixed.
thanks for posting fix
