Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 01-06-2009, 01:08 AM
j.wells13 j.wells13 is offline
Exclamation 2000 Olds Bravada Starting issue
Okay I have a 2000 Olds Bravada with a starting issue. It will not start (hot or cold) without starting fluid once i turn it over a few times after spraying fluid in it it will run fine with no problems at all unless I shut it off I have to spary the intake again. I have tried alot it has a year old fuel pump, new fuel filter, Fuel Injector Pressure Regulator, (i had the pressure check and it was fine) a hole tune up. I have everyone stumped on whats wrong with it. I am thinking it may be a sensor or some thing like that. Also I can hear the fuel pump kick on when I start it.
Any help or idea's????????????
Old 01-06-2009, 08:35 AM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
Re: 2000 Olds Bravada Starting issue
What brand of fuel pump was installed a year ago?
Define 'fine' on the fuel pressure - what were the actual numbers?
1993 Olds Bravada 4.3L CPI
1999 GMC Safari SLE AWD
2002 Chevy Astro LT AWD
Old 01-06-2009, 09:16 AM
Airtex was the brand and the fuel pressure they never told me the psi
Old 01-06-2009, 09:23 AM
As I'm sure many more will tell you, Airtex pumps are junk - Delco only on our trucks.
You need to get the fuel pressure numbers.
Old 01-06-2009, 10:28 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
I would guarantee the fuel pressure is under 56 PSI! If it is it will not start, but it will run once it is started. It sounds strange but my theory is that since engine vacuum is much greater running it requires less pressure to open the poppets because there is less resistance on the other side.
Old 01-06-2009, 06:09 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
The difficult start but decent run status indicates a fuel problem. The fuel injection system requires 61-65psi at the test port which is a good place to start your trouble shooting.
Old 01-09-2009, 02:07 AM
Josh Smith's Avatar
Josh Smith Josh Smith is offline
Send a message via Yahoo to Josh Smith
I'm betting the priming cycle is not being done.
1993 Olds Bravada, tow package, power everything and leather seats. Currently in restoration. - RIP. Your engine and drive train were excellent, but in the end, too much rust.
2000 Blazer, loaded, looks showroom new, bought April 4th, 2009
Old 01-09-2009, 06:18 AM
we primed it after the new fuel filter was put on. i am getting the psi checked out this weekend and getting a scanner hooked up too it.
Old 01-09-2009, 08:30 AM
Airjer_'s Avatar
What are you talking about? Listen when it comes to automotive repair, even if your trying to help sometimes its just better not to say anything when you are not sure what you are talking about to avoid spreading information that really does not make sense or adds confusion to an already frustrating problem for the vehicles owner!
Yes there is a 3 to 5 second "prime" when you turn the key on. But if you crank the engine over than the fuel pump should be running as well. So regardless of the "prime" the fuel pump should run when cranking. In this case we know it is because after adding starting fluid the vehicle will start and run! This is a classic symptom of low fuel pressure typically caused buy a bad fuel pump. See me previous post for details!!!
Old 01-10-2009, 09:44 AM
AF - Advisor
Fuel Pressure test kits are available at most auto parts stores for around $40 and sometimes they're less expensive at places like Harbor Freight.
Here's where you connect.
