Old 01-05-2009, 09:25 PM
Joebowler98 Joebowler98 is offline
2002 T&C Windshield Washer pump question
Wondering if there are 2 windshield washer pumps on it? The back one squirts the rear window but. the front ones don't squirt at all? Do you think the hose is just plugged or are there two of them? Is the repair easy for an average guy? Thanks for any answers.
Old 01-05-2009, 11:12 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2002 T&C Windshield Washer pump question
Each has their seperate pumps. Both run off the same fuse. Turn the ignition to run then squirt it. You should hear the pump. If not, it's either the pump, switch, forward control module, wiring or it's frozen. If you hear the pump and it's not squirting, disconnect the hose from a nozzle. If you now get fluid the nozzle is clogged. Ream it with a toothpick from the bottom and a small piece of wire from the top.
Got a warm garage you can park in? Maybe a hair dryer?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
