Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-05-2009, 08:28 PM
brielly brielly is offline
Coolant
Hello I just got my new to me 2000 5.7 tahoe. I bought it from a dealer who was supposed to replace the radiator before delivering it to me. They replaced the radiator but when I looked in the coolant recovery tank it looked clear and in fact I'm pretty sure its water. I called and asked and they said it would take time for the water in the tank to blend with the coolant. Sounded like bs but i waited until the engine cooled and looked in the radiator and that fluid is clear. I'm pretty certain they screwd me just o save a buck on coolant but was wondering if there was any possibility to their claim? Unfortunately they're an hour away so I can't just go back to complain I guess I will need to drain the entire system. Can anyone tell me the location of the block drains? Thanks
Old 01-06-2009, 12:00 AM
roadrunner2 roadrunner2 is offline
Re: Coolant
They must have given you atleast a 30 day warranty. One hour drive or not, take it back and tell them to put proper coolant in it and flush all the water out.
I hope to hell you don't live where the temp goes to and below the freezing mark because that engine will freeze overnight and you can start repairs by replacing burst frost plugs (If you're lucky).
GM uses Dexcool coolant but you can (with a thorough cooling system flush) also replace that with the old standard green coolant. Use a 50/50 mix coolant/water. Just do not mix Dexcool with another coolant as they are not compatible.
The problem with doing nothing is not knowing when you're finished.
Old 01-06-2009, 12:05 AM
Re: Coolant
Let me add: I'm not certain if there are or where the block drains are as my '02 Tahoe (5.3L) isn't here so I can't check the Haynes manual I have for it.
Old 01-07-2009, 05:51 PM
Re: Coolant
Well I'm pretty sure the dealer screwed me on this. When I called they couldn't give me a straight answer and kept trying to say as I drive the fluid would mix in and turn more orange. What a bunch of BS. I'm having it flushed and filled properly and giving them the bill (and making a scene if they try not to pay it) As for now its n my garage where it will be warm enough not to freeze up. I guess chevy dealers are so hurting they'll try to cut corners wherever they can.
Old 01-07-2009, 07:31 PM
j cAT j cAT is offline
Re: Coolant
I'm sorry to hear that you have been screwed by the GM dealership...haven't we all...You are correct to have this work done correctly at a recommended service centre that will provide professional service..Rather than have them screw it up ...
If they refuse to pay for the coolant service ,you could possibly go to small claims court and recover any costs...if available where you live..
Old 01-08-2009, 04:13 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Coolant
Sounds like it wasn't a GM dealer you bought it from...they're not usually that stupid or ignorant...usually.
Yes, do a complete flush of the green stuff before replacing with the orange Dex-Cool. The two do not intermix at all.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-08-2009, 06:58 PM
Re: Coolant
[quote=jdmccright]Sounds like it wasn't a GM dealer you bought it from...they're not usually that stupid or ignorant...usually.
quote]
this is more likely a rip off .....not ignorance....
Old 01-08-2009, 09:54 PM
Re: Coolant
Unfortunately it was in fact a chevy dealership and I'm fairly certain they tried to do this to save a buck figuring I lived an hour away and they could get a way with it. Too bad for them because I have to go back there to pick up my plates and registration. When I do I will have my bill in hand and i'm not leaving without reimbusement. I will also complain to the BBB and consumer affairs as well. Avoid Mall Chevrolet in Cherry Hil NJ like the plague!
Old 01-09-2009, 10:45 PM
Re: Coolant
Before you 'boil over' let me suggest you talk to the dealer manager and see if he/she can rectify the problem first.
If this doesn't produce the required result, contact the area rep of the GM dealership.
The 'rule of thumb' is to give the dealer three strikes before you call in the guard.
Foremost, get any and ALL communication in writing and have it signed.
Old 01-10-2009, 09:26 AM
Re: Coolant
they will never put it in writing....what he needs is a witness, then the dealership will probably pay for the coolant service..
with that other person present there, the attitude will be much different..
