Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Interiors
Old 01-05-2009, 07:16 PM
Eclipser80 Eclipser80 is offline
Send a message via AIM to Eclipser80
95 seat belts
So still working on the idle problem but until then my issue is the seat belts..i need to know what to unscrew to get access to them, they are not working right so when i take it off it doesnt retract at all. Is there something i need to tighten or replace them all together?
1995 Mitsubishi Eclipse GS Non-turbo
Old 01-07-2009, 08:23 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 95 seat belts
There is a spring in the seat belt that pulls it back in. The spring could be broken or something. It would probably just be easiest to replace them. Im sure you could get some cheap.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-07-2009, 09:31 PM
Re: 95 seat belts
ok but i was wondering how i get to them? do i have to pull the back seats out to pull the back panel off?
Old 01-08-2009, 12:28 AM
Holset powered 420a
Re: 95 seat belts
Yes you do, there is a screw that holds the panel on thats covered by the seat. There are also 2 more behind the seat back so lay that down and you can access them. Pull the panel and the clips should break loose now.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-08-2009, 01:25 AM
Re: 95 seat belts
ok thanks didnt wanna just dive in and starting taking things out i didnt need to.. i looked in the Haynes book and i couldn't find anything about it
