Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-05-2009, 04:55 PM
dwaynlakrz dwaynlakrz is offline
1999 regal gs
i have a 1999 regal gs 3800 --my led's in the dash are out --the drive ones thru overdrive--plus the miles--how can these be fixed.
Old 01-05-2009, 06:09 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1999 regal gs
That is a bummer. Either replacement of the IP cluster with a new or used one in most cases. Problem with a new or used IP cluster is you will need the odometer module reprogrammed with the last known mileage. However, a few companies repair the IP cluster but it will need removal and sent off to them. Other option is a possible DIY fix that may work. Let me know if you need it to review.
Timeslip 08/12/06
AF Community Guidelines
Old 01-05-2009, 06:42 PM
Re: 1999 regal gs
thanks--is the ip cluster hard to remove
Old 01-06-2009, 06:33 AM
BNaylor's Avatar
Re: 1999 regal gs
The IP cluster is easy once the dash bezel is removed. That black plastic piece that runs from left to right. Once the bezel is removed the cluster assembly has a few plastic retainers that you remove. Once those are removed then just undo the electrical connectors.
Timeslip 08/12/06
