Manual Sliding Door will not lock/unlock
I have a 2006 SV6 - AWD - I noticed the other day that the sliding door will not lock/unlock with my keyless remote. The other doors lock and unlock. Any ideas.
Michael |
Re: Manual Sliding Door will not lock/unlock
welcome to a/f. clean the brass contacts for the door. thats should do it.
try spraying wd-40 in the prongs in the door that make contact with the plate on the door jam.make sure they move back and forth and are clean on the ends.these like to get corrosion on the ends[green stuff]
from what i can tell the contact plate on the door jam is like a switch with wires on the backside of it. could be a loose wire on the backside of the plate or behind the one in the door as it looks to work the same way.are the ends on the door and the contact plate bright or dull looking ? might shine the ends and contact points on the plate with realfine emry cloth then wipe some dialectric cream on them to keep corrosion off.this is what i did to mine.
what about the prong ends?as both the plate and prongs have to make a good contact
right on. good to see you got it. later
