Ride Height
In another thread "Rear Lid Lift" a couple of you had suggested a ride height spring setting of 3" Front, 3 1/2" Rear. I did a preliminary check (without any weight in the drivers seat). Here are my findings:
Front/left 3.7" Front/right 3.55" Rear/left 5.1" Rear/right 4.75 The left side averages higher than the right-presumably because of no drivers weight. I took my measurements at the bottom of the frame directly in line with the center of the wheel hub. These numbers are way higher than what you guys are recommending. So do I lower the car strictly by spinning the collar on the shocks? Do I need a spanner pin wrench or are you guys just putting a couple of pins in and wrenching it the hard way? I'll be swithcing out the springs to the 550#/350# values while making the height adjustments.
Uwe W. Panoz GTS Porsche 996 Turbo
Re: Ride Height
i always check mine on leval ground and i mesure all four finder whells right in the middle of fender to the ground. do this a see what mesurments you get? but you have to have it ground or cement to get the right highth and this is the first thing i do before i start alighning it and tire pressure.
Re: Ride Height
I think the fenders are too flimsy to measure-plastic body parts.
I did check it with correct tire pressure, on my flat concrete garage floor. I used machinists ground gage blocks shimmed between the floor and the frame member- just to be persnickety about it.
Re: Ride Height
Corner weighting requirements will obviously depend on what the predominant corners (i.e. more rights than lefts or vice versa) are at your local circuit. Chuck in your new springs, set the basic ride height and then put in any additional corner weight. You will be very happy with decision to run the 550 / 350 combo it makes for way more fun. Kel. |
Re: Ride Height
It's best to measure the frame height just to the inside of each wheel. Mine is set to 4.5" and 5.5" but when I swap out the 550's with 750's (move the 550's to the rear) I plan to lower it down to 3.5"/4.5"
Eric H (in case you couldn't guess) GT-WC #22 (now #62 and Blue) |
Re: Ride Height
Just for reference, the specs from Panoz are 3.5" in the front and 4.0-4.25" in the rear. It would be a good place to start.
![]() Craig Wright PGTRA #21 '05 Ford GT '65 XKE (newest addition) |
