Go Back   Automotive Forums Car Chat > Buick > Century
Old 01-05-2009, 01:05 AM
Fri Fri is offline
Re: 98 Buick Turn Signal
Hi,
I just joined here because I was looking for info about this same problem, except it is with my front left turn signal on a 99 Century. The running light part of the bulb works just fine, but when I signal left, the light stays on solid instead of flashing. If anyone has any info on this problem, I'd really appreciate the help.
Thanks!
Old 01-05-2009, 07:18 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Welcome to AF and the forum.
Due to old post guidelines I moved your post to its own thread.
Since the flasher works with the right turn signals you can rule that out. It sounds like a bad multifunction switch (turn signal stalk) or related wiring.
Timeslip 08/12/06
AF Community Guidelines
Old 01-06-2009, 12:00 AM
Fri Fri is offline
Re: 99 Turn Signal
Thanks for the welcome and the reply! I read the guidelines right after I finished posting. Sorry about that.
Is it possible that the problem is with the wiring in the headlamp assembly?
Thanks,
Fri
Old 01-06-2009, 06:30 AM
BNaylor's Avatar
Re: 99 Turn Signal
It is possible. Is it both front and rear left signals acting up?
Timeslip 08/12/06
Old 01-06-2009, 08:38 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 99 Turn Signal
The front turn signal sockets are a known issue on these cars too. It's possible that the connection for the high watt element is bad/melted, or the wiring to it. Here's a link to a picture of the part from AC-Delco's website
http://198.208.187.182/internet/View...rtNumber=LS115
Don't rule out a bad bulb either (as the bulb has two elements, one for the running lights, and one for the turn signals), but normally a burnt bulb will cause rapid flashing rather than no flashing on this model car.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-06-2009, 07:46 PM
Fri Fri is offline
Re: 99 Turn Signal
I have a little more information about the light. The running light does not come on unless the headlights are on. The passenger side bulb works just as it should (on whether headlights are on or off and flashes normally). The rear left turn signal works normally, except it flashes fast due to the front left bulb not flashing. I know its not the bulb because it has done this with multiple bulbs. When this was my parent's car, new bulbs would flash normally for a few days before going out. Now when I put a new bulb in, there is no flashing at all.
Thanks again,
Fri
Old 01-07-2009, 04:21 PM
richtazz's Avatar
Re: 99 Turn Signal
Since the rear bulb is flashing fast and changing the buld no longer helps (but used to), your problem is almost 100% the socket the bulb plugs into or the wiring to it.
Old 01-07-2009, 09:02 PM
Fri Fri is offline
Re: 99 Turn Signal
Thanks for all the help. I'll be ordering a new socket tomorrow.
Fri
