Gutless, no codes, power surges.
It's been doing this for a couple of months now. Idles fine, some power at low RPM, not much, definitely no power at high RPM. Almost sounds like a restriction in cat, but not sure. Changed fuel filter, fuels looks Grey on both side of filter. Had a bit more power after changing fuel filter, but then power loss seemed to get worse after a while. Changed plugs and wires. Disconnected exhaust after cat, still does it. Actron scanner comes up with no codes. I did a road test with it connected and recorded what happened. If any one can look at the readout and tell me what they think, PM me and I will email the file for you to look at the results. One reading on the MAF Flow @ 100% throttle was @ 18.82, but other times it like 118.82, 66.73, 110.66, 99.85, and 89.85. Not sure if that matters, but at Full throttle, in first gear, I could only go 44MPH, and after about 5 seconds of 44MPH, it finally shifts up. It feals really gutless on the way to 44MPH. I was thinking maybe one of the coils, or maybe the fuel pump? Maybe when the fuel filter was being clogged, it broke the fuel pump so it puts out low pressure. Not sure what to do next.
![]() My Grand Am Picture Site _____________________________________________ 2002 Grand Am GT 77 Dodge Power Wagon 2006 Charger SXT 3.5L V-6 2011 Charger RT 5.7L Hemi 2008 CLK350 Convertible |
Re: Gutless, no codes, power surges.
You can post the file and the members and or the mods can tell you what if any problems there might be.
1"=rj$MAF FLOW GR/SE 70.96
MAP KPA 103 COOLANT F 177 IAT F 75 IGN ADVANCE DE 23.5 ST FTRM1 % 0.0 LT FTRM1 % -3.4 VEH SPEED MPH 24 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.905 ST FTRM11 % 0.0 O2S12 V 0.905 MIL DIST mi 0 OBD2 STAT CA/US Frame 7 Time 5.0 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 4650 CALC LOAD % 77.6 MAF FLOW GR/SE118.82 MAP KPA 99 COOLANT F 176 IAT F 73 IGN ADVANCE DE 24.5 ST FTRM1 % 0.0 LT FTRM1 % -3.4 VEH SPEED MPH 38 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.870 ST FTRM11 % 0.0 O2S12 V 0.920 MIL DIST mi 0 OBD2 STAT CA/US Frame 8 Time 5.6 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 5160 CALC LOAD % 66.2 MAF FLOW GR/SE 18.82 MAP KPA 35 COOLANT F 176 IAT F 66 IGN ADVANCE DE 20.0 ST FTRM1 % -1.0 LT FTRM1 % -7.7 VEH SPEED MPH 40 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.850 ST FTRM11 % -5.1 O2S12 V 0.910 MIL DIST mi 0 OBD2 STAT CA/US Frame 9 Time 6.3 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1199 CALC LOAD % 4.7 MAF FLOW GR/SE 7.52 MAP KPA 37 COOLANT F 176 IAT F 68 IGN ADVANCE DE 20.0 ST FTRM1 % -3.4 LT FTRM1 % -10.4 VEH SPEED MPH 34 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.165 ST FTRM11 % 0.0 O2S12 V 0.875 MIL DIST mi 0 OBD2 STAT CA/US Frame 10 Time 7.0 MIL STATUS OFF ABSLT TPS % 7.8 ENG SPEED RPM 1745 CALC LOAD % 9.8 MAF FLOW GR/SE 18.42 MAP KPA 68 COOLANT F 176 IAT F 68 IGN ADVANCE DE 46.0 ST FTRM1 % 0.0 LT FTRM1 % -5.1 VEH SPEED MPH 34 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.415 ST FTRM11 % 2.3 O2S12 V 0.820 MIL DIST mi 0 OBD2 STAT CA/US Frame 11 Time 7.7 MIL STATUS OFF ABSLT TPS % 34.1 ENG SPEED RPM 2943 CALC LOAD % 9.8 MAF FLOW GR/SE 14.39 MAP KPA 29 COOLANT F 177 IAT F 68 IGN ADVANCE DE 24.5 ST FTRM1 % 0.7 LT FTRM1 % -10.4 VEH SPEED MPH 36 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.605 ST FTRM11 % -3.4 O2S12 V 0.805 MIL DIST mi 0 OBD2 STAT CA/US Frame 12 Time 8.4 MIL STATUS OFF ABSLT TPS % 7.4 ENG SPEED RPM 1759 CALC LOAD % 9.4 MAF FLOW GR/SE 14.65 MAP KPA 47 COOLANT F 177 IAT F 68 IGN ADVANCE DE 47.0 ST FTRM1 % -2.2 LT FTRM1 % -5.1 VEH SPEED MPH 36 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.095 ST FTRM11 % -1.0 O2S12 V 0.795 MIL DIST mi 0 OBD2 STAT CA/US Frame 13 Time 9.1 MIL STATUS OFF ABSLT TPS % 15.2 ENG SPEED RPM 1717 CALC LOAD % 15.6 MAF FLOW GR/SE 23.58 MAP KPA 79 COOLANT F 179 IAT F 68 IGN ADVANCE DE 25.0 ST FTRM1 % 2.3 LT FTRM1 % -10.4 VEH SPEED MPH 36 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.760 ST FTRM11 % 1.5 O2S12 V 0.785 MIL DIST mi 0 OBD2 STAT CA/US Frame 14 Time 9.8 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1016 CALC LOAD % 4.3 MAF FLOW GR/SE 6.53 MAP KPA 37 COOLANT F 179 IAT F 68 IGN ADVANCE DE 20.0 ST FTRM1 % 0.8 LT FTRM1 % -10.4 VEH SPEED MPH 18 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.080 ST FTRM11 % -3.4 O2S12 V 0.785 MIL DIST mi 0 OBD2 STAT CA/US Frame 15 Time 10.5 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 695 CALC LOAD % 3.5 MAF FLOW GR/SE 5.61 MAP KPA 48 COOLANT F 179 IAT F 69 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -5.1 VEH SPEED MPH 1 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.050 ST FTRM11 % 2.3 O2S12 V 0.140 MIL DIST mi 0 OBD2 STAT CA/US Frame 16 Time 11.1 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 2691 CALC LOAD % 45.0 MAF FLOW GR/SE 66.73 MAP KPA 102 COOLANT F 179 IAT F 69 IGN ADVANCE DE 24.5 ST FTRM1 % 0.0 LT FTRM1 % -3.4 VEH SPEED MPH 23 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.855 ST FTRM11 % 0.0 O2S12 V 0.915 MIL DIST mi 0 OBD2 STAT CA/US Frame 17 Time 11.8 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 4522 CALC LOAD % 75.2 MAF FLOW GR/SE110.66 MAP KPA 101 COOLANT F 179 IAT F 66 IGN ADVANCE DE 18.5 ST FTRM1 % 0.0 LT FTRM1 % -3.4 VEH SPEED MPH 37 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.860 ST FTRM11 % 0.0 O2S12 V 0.910 MIL DIST mi 0 OBD2 STAT CA/US Frame 18 Time 12.5 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 5552 CALC LOAD % 67.4 MAF FLOW GR/SE 99.85 MAP KPA 103 COOLANT F 177 IAT F 64 IGN ADVANCE DE 16.0 ST FTRM1 % 0.0 LT FTRM1 % -4.6 VEH SPEED MPH 40 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.830 ST FTRM11 % 0.0 O2S12 V 0.905 MIL DIST mi 0 OBD2 STAT CA/US Frame 19 Time 13.2 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 3556 CALC LOAD % 57.2 MAF FLOW GR/SE 89.58 MAP KPA 103 COOLANT F 177 IAT F 62 IGN ADVANCE DE 25.5 ST FTRM1 % 0.8 LT FTRM1 % -5.1 VEH SPEED MPH 45 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.785 ST FTRM11 % -2.2 O2S12 V 0.890 MIL DIST mi 0 OBD2 STAT CA/US Frame 20 Time 13.9 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1405 CALC LOAD % 5.0 MAF FLOW GR/SE 7.94 MAP KPA 34 COOLANT F 179 IAT F 62 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -11.6 VEH SPEED MPH 44 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.130 ST FTRM11 % -1.0 O2S12 V 0.850 MIL DIST mi 0 OBD2 STAT CA/US Frame 21 Time 14.6 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1293 CALC LOAD % 4.7 MAF FLOW GR/SE 7.23 MAP KPA 44 COOLANT F 179 IAT F 64 IGN ADVANCE DE 24.5 ST FTRM1 % 1.5 LT FTRM1 % -11.6 VEH SPEED MPH 38 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.075 ST FTRM11 % 0.0 O2S12 V 0.845 MIL DIST mi 0 OBD2 STAT CA/US Frame 22 Time 15.3 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1026 CALC LOAD % 4.3 MAF FLOW GR/SE 6.42 MAP KPA 37 COOLANT F 183 IAT F 64 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -11.6 VEH SPEED MPH 31 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.565 ST FTRM11 % -1.0 O2S12 V 0.830 MIL DIST mi 0 OBD2 STAT CA/US Frame 23 Time 16.0 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 897 CALC LOAD % 3.9 MAF FLOW GR/SE 6.00 MAP KPA 40 COOLANT F 183 IAT F 66 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -11.6 VEH SPEED MPH 18 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.075 ST FTRM11 % 0.7 O2S12 V 0.820 MIL DIST mi 0 OBD2 STAT CA/US Frame 24 Time 16.6 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 832 CALC LOAD % 3.9 MAF FLOW GR/SE 6.04 MAP KPA 46 COOLANT F 185 IAT F 66 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -11.6 VEH SPEED MPH 5 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.770 ST FTRM11 % 0.0 O2S12 V 0.815 MIL DIST mi 0 OBD2 STAT CA/US Frame 25 Time 17.3 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 791 CALC LOAD % 10.5 MAF FLOW GR/SE 20.50 MAP KPA 68 COOLANT F 186 IAT F 68 IGN ADVANCE DE 24.5 ST FTRM1 % -1.0 LT FTRM1 % -5.1 VEH SPEED MPH 8 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.095 ST FTRM11 % 3.9 O2S12 V 0.780 MIL DIST mi 0 OBD2 STAT CA/US Frame 26 Time 18.0 MIL STATUS OFF ABSLT TPS % 36.4 ENG SPEED RPM 2800 CALC LOAD % 35.6 MAF FLOW GR/SE 54.22 MAP KPA 102 COOLANT F 186 IAT F 66 IGN ADVANCE DE 32.0 ST FTRM1 % 5.4 LT FTRM1 % -5.1 VEH SPEED MPH 22 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.450 ST FTRM11 % 0.0 O2S12 V 0.760 MIL DIST mi 0 OBD2 STAT CA/US Frame 27 Time 18.7 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1003 CALC LOAD % 4.7 MAF FLOW GR/SE 7.07 MAP KPA 43 COOLANT F 185 IAT F 66 IGN ADVANCE DE 20.0 ST FTRM1 % 0.8 LT FTRM1 % -11.6 VEH SPEED MPH 12 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.140 ST FTRM11 % -1.0 O2S12 V 0.760 MIL DIST mi 0 OBD2 STAT CA/US Frame 28 Time 19.4 MIL STATUS OFF ABSLT TPS % 4.3 ENG SPEED RPM 897 CALC LOAD % 11.3 MAF FLOW GR/SE 14.20 MAP KPA 55 COOLANT F 183 IAT F 66 IGN ADVANCE DE 43.5 ST FTRM1 % 0.0 LT FTRM1 % -5.1 VEH SPEED MPH 9 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.215 ST FTRM11 % 0.0 O2S12 V 0.755 MIL DIST mi 0 OBD2 STAT CA/US Frame 29 Time 20.1 MIL STATUS OFF ABSLT TPS % 25.0 ENG SPEED RPM 2062 CALC LOAD % 24.3 MAF FLOW GR/SE 38.35 MAP KPA 102 COOLANT F 183 IAT F 66 IGN ADVANCE DE 22.0 ST FTRM1 % 0.0 LT FTRM1 % -3.4 VEH SPEED MPH 16 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.155 ST FTRM11 % 0.0 O2S12 V 0.775 MIL DIST mi 0 OBD2 STAT CA/US Frame 30 Time 20.8 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 855 CALC LOAD % 4.7 MAF FLOW GR/SE 6.93 MAP KPA 47 COOLANT F 183 IAT F 66 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -11.6 VEH SPEED MPH 5 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.335 ST FTRM11 % 0.0 O2S12 V 0.755 MIL DIST mi 0 OBD2 STAT CA/US Frame 31 Time 21.5 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 686 CALC LOAD % 3.5 MAF FLOW GR/SE 5.52 MAP KPA 79 COOLANT F 183 IAT F 68 IGN ADVANCE DE 21.5 ST FTRM1 % -3.4 LT FTRM1 % -6.3 VEH SPEED MPH 6 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.880 ST FTRM11 % 0.0 O2S12 V 0.885 MIL DIST mi 0 OBD2 STAT CA/US Frame 32 Time 22.2 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 3081 CALC LOAD % 50.1 MAF FLOW GR/SE 78.74 MAP KPA 103 COOLANT F 183 IAT F 66 IGN ADVANCE DE 22.5 ST FTRM1 % 0.0 LT FTRM1 % -3.4 VEH SPEED MPH 27 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.855 ST FTRM11 % 0.0 O2S12 V 0.885 MIL DIST mi 0 OBD2 STAT CA/US Frame 33 Time 22.8 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 4928 CALC LOAD % 75.2 MAF FLOW GR/SE109.92 MAP KPA 103 COOLANT F 183 IAT F 64 IGN ADVANCE DE 18.0 ST FTRM1 % 0.0 LT FTRM1 % -3.4 VEH SPEED MPH 38 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.835 ST FTRM11 % 0.0 O2S12 V 0.870 MIL DIST mi 0 OBD2 STAT CA/US Frame 34 Time 23.5 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 5552 CALC LOAD % 65.0 MAF FLOW GR/SE 98.17 MAP KPA 102 COOLANT F 183 IAT F 60 IGN ADVANCE DE 14.0 ST FTRM1 % 0.0 LT FTRM1 % -4.6 VEH SPEED MPH 40 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.740 ST FTRM11 % 0.0 O2S12 V 0.860 MIL DIST mi 0 OBD2 STAT CA/US Frame 35 Time 24.2 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 3331 CALC LOAD % 45.8 MAF FLOW GR/SE 67.48 MAP KPA 103 COOLANT F 183 IAT F 59 IGN ADVANCE DE 6.5 ST FTRM1 % 0.0 LT FTRM1 % -3.4 VEH SPEED MPH 44 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.820 ST FTRM11 % 0.0 O2S12 V 0.900 MIL DIST mi 0 OBD2 STAT CA/US Frame 36 Time 24.9 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1856 CALC LOAD % 7.0 MAF FLOW GR/SE 10.35 MAP KPA 39 COOLANT F 185 IAT F 59 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -11.6 VEH SPEED MPH 44 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.640 ST FTRM11 % 0.7 O2S12 V 0.830 MIL DIST mi 0 OBD2 STAT CA/US Frame 37 Time 25.6 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1267 CALC LOAD % 4.7 MAF FLOW GR/SE 7.28 MAP KPA 36 COOLANT F 186 IAT F 60 IGN ADVANCE DE 24.5 ST FTRM1 % 0.8 LT FTRM1 % -11.6 VEH SPEED MPH 37 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.060 ST FTRM11 % 0.0 O2S12 V 0.815 MIL DIST mi 0 OBD2 STAT CA/US Frame 38 Time 26.3 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 967 CALC LOAD % 4.3 MAF FLOW GR/SE 6.39 MAP KPA 37 COOLANT F 188 IAT F 62 IGN ADVANCE DE 20.0 ST FTRM1 % -3.4 LT FTRM1 % -11.6 VEH SPEED MPH 30 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.585 ST FTRM11 % -3.4 O2S12 V 0.800 MIL DIST mi 0 OBD2 STAT CA/US Frame 39 Time 27.0 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 941 CALC LOAD % 3.9 MAF FLOW GR/SE 5.97 MAP KPA 39 COOLANT F 190 IAT F 62 IGN ADVANCE DE 20.0 ST FTRM1 % -2.2 LT FTRM1 % -11.8 VEH SPEED MPH 16 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.780 ST FTRM11 % -2.2 O2S12 V 0.790 MIL DIST mi 0 OBD2 STAT CA/US Frame 40 Time 27.7 MIL STATUS($10) --- ABSLT TPS($10) --- ENG SPEED($10) --- CALC LOAD($10) --- MAF FLOW($10) --- MAP($10) --- COOLANT($10) --- IAT($10) --- IGN ADVANCE($10) --- ST FTRM1($10) --- LT FTRM1($10) --- VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 OPEN1 O2S11 V 0.045 ST FTRM11 % -91.1 O2S12 V 0.070 MIL DIST mi 5427 OBD2 STAT N/A Frame -1 Time -14.4 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 0 CALC LOAD % 0.0 MAF FLOW GR/SE 0.00 MAP KPA 0 COOLANT F -40 IAT F -40 IGN ADVANCE DE -64.6 ST FTRM1 % -100.6 LT FTRM1 % -100.6 VEH SPEED MPH 0 FUEL SYS 1 N/A FUEL SYS 2 N/A O2S11 V 0.000 ST FTRM11 % -100.6 O2S12 V 0.000 MIL DIST mi 0 OBD2 STAT N/A Frame 28415 Time1404.2
What size engine is it? so you step on the pedal 100% WOT engine pulls for a while rpm goes very high but then you do not feel any torque for a two sec then finally shifts in second gear? your trans is slipping.
on v6 maf at idle should be 3 to 4 g/s not 7.5 |
you should record one at idle engine warm, but anyway your frame #31 is the closest one to engine completely at idle and warm. So take a look at MAP kpa at idle 686 RPM throttle 0% at that point engine should produce close to 21 inHG of vacuum. Map usually measures amount that when you subtract from your curent atmosperic pressure which is average 29in Hg you will get how much of inHG your engine produces. So if we convert 79kpa to inHG we get 23.41 inHG then 29-23.41=5.59 in hg which tells me eather you have huge vacuum leak or your MAP is bad. Alsoe with ignition on engine off your map shoud read atmospheric pressure of close to 29.5 inHG or about 99.52 kpa.
Also look at the frame #39 here your Map is showing normal kpa. So it could be intermittent MAP. Also try this: remove that big rubber hose that goes between your MAF and your air filter box test it without that hose so engine will suck air from under the hood it will make a cool sound by the way but just wanted to see if you will have the same problem with power loss. Please try this it will not hurt your engine for 2-3 minutes without air filter trust me. do not go and change MAP right away record one reading at idle engine warm and 0 mph. Then engine off ignition on record reading. also if you can tell us what the IAC count is at idle. |
The engine is the 3400 V-6, and just so happens, I had taken the top of the air cleaner off, so the black part between the air cleaner and the MAF was off. It still ran the same. Now if there was a huge vacuum leak, I'm sure I would hear that with the hood up. I don't hear anything obviously leaking, so I'm going to go with the MAP answer. I did a test at idle and it was running around 33 + -. When I did the road test with the scanner connected, I started in Drive, so that may be why it's at 44, but at the end of the next print out of the scanner, is in the driveway at idle in Neutral and it's @ 31-48. Now that MAP is the little black sealed box in top in the middle isn't it. I have one from when I had my Camero. I replaced it and when I was in England, I crashed it, so I just had to keep that thing. It cost me $75 used. I know it's in the garage somewhere. Would it still be the same piece today as it was on my 86 Camero with 2.8 V-6? I've seen those same boxes on just about all those GM cars, even the V-8's look like the same part.
Back to trouble shooting, I do notice that sometimes when I take off from a stop, it does seem to act up more. Sometimes it does better than other times. I always get that surge of power at 3000 RPM's. Can't take away the power band. It just seems more noticeable with it running like this.
New Actron scanner printout.
Started in D, ended in P in driveway idling. Recorded Data MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 688 CALC LOAD % 3.1 MAF FLOW GR/SE 4.78 MAP KPA 42 COOLANT F 185 IAT F 64 IGN ADVANCE DE 21.5 ST FTRM1 % 0.0 LT FTRM1 % -9.2 VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.100 ST FTRM11 % -1.0 O2S12 V 0.545 MIL DIST mi 0 OBD2 STAT CA/US Frame 0 Time 0.0 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 708 CALC LOAD % 3.1 MAF FLOW GR/SE 4.79 MAP KPA 42 COOLANT F 185 IAT F 64 IGN ADVANCE DE 21.5 ST FTRM1 % 0.8 LT FTRM1 % -9.2 VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.080 ST FTRM11 % 0.0 O2S12 V 0.555 MIL DIST mi 0 OBD2 STAT CA/US Frame 1 Time 0.9 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 705 CALC LOAD % 3.1 MAF FLOW GR/SE 4.87 MAP KPA 43 COOLANT F 185 IAT F 64 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -9.2 VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.075 ST FTRM11 % -2.2 O2S12 V 0.555 MIL DIST mi 0 OBD2 STAT CA/US Frame 2 Time 1.5 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 701 CALC LOAD % 3.1 MAF FLOW GR/SE 4.89 MAP KPA 43 COOLANT F 185 IAT F 64 IGN ADVANCE DE 20.0 ST FTRM1 % -1.0 LT FTRM1 % -9.2 VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.755 ST FTRM11 % 0.8 O2S12 V 0.555 MIL DIST mi 0 OBD2 STAT CA/US Frame 3 Time 2.2 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 668 CALC LOAD % 2.7 MAF FLOW GR/SE 4.78 MAP KPA 44 COOLANT F 185 IAT F 64 IGN ADVANCE DE 22.5 ST FTRM1 % -1.0 LT FTRM1 % -9.2 VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.070 ST FTRM11 % -1.0 O2S12 V 0.555 MIL DIST mi 0 OBD2 STAT CA/US Frame 4 Time 2.9 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 670 CALC LOAD % 3.1 MAF FLOW GR/SE 4.95 MAP KPA 44 COOLANT F 185 IAT F 64 IGN ADVANCE DE 21.0 ST FTRM1 % 0.8 LT FTRM1 % -9.2 VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.705 ST FTRM11 % 0.0 O2S12 V 0.800 MIL DIST mi 0 OBD2 STAT CA/US Frame 5 Time 3.6 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 2770 CALC LOAD % 46.6 MAF FLOW GR/SE 75.00 MAP KPA 102 COOLANT F 185 IAT F 64 IGN ADVANCE DE 26.0 ST FTRM1 % 0.0 LT FTRM1 % -2.2 VEH SPEED MPH 24 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.890 ST FTRM11 % 0.0 O2S12 V 0.905 MIL DIST mi 0 OBD2 STAT CA/US Frame 6 Time 4.3 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 4838 CALC LOAD % 80.0 MAF FLOW GR/SE119.53 MAP KPA 102 COOLANT F 185 IAT F 62 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -2.2 VEH SPEED MPH 39 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.840 ST FTRM11 % -1.0 O2S12 V 0.920 MIL DIST mi 0 OBD2 STAT CA/US Frame 7 Time 5.0 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1309 CALC LOAD % 24.3 MAF FLOW GR/SE 29.00 MAP KPA 45 COOLANT F 186 IAT F 60 IGN ADVANCE DE 26.0 ST FTRM1 % 0.0 LT FTRM1 % -9.2 VEH SPEED MPH 39 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.105 ST FTRM11 % 0.7 O2S12 V 0.845 MIL DIST mi 0 OBD2 STAT CA/US Frame 8 Time 5.7 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1185 CALC LOAD % 4.3 MAF FLOW GR/SE 6.79 MAP KPA 39 COOLANT F 186 IAT F 60 IGN ADVANCE DE 20.0 ST FTRM1 % 0.8 LT FTRM1 % -10.4 VEH SPEED MPH 35 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.705 ST FTRM11 % 0.8 O2S12 V 0.815 MIL DIST mi 0 OBD2 STAT CA/US Frame 9 Time 6.3 MIL STATUS OFF ABSLT TPS % 7.8 ENG SPEED RPM 1531 CALC LOAD % 11.7 MAF FLOW GR/SE 19.88 MAP KPA 64 COOLANT F 188 IAT F 60 IGN ADVANCE DE 29.0 ST FTRM1 % -4.9 LT FTRM1 % -2.2 VEH SPEED MPH 34 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.855 ST FTRM11 % 0.0 O2S12 V 0.785 MIL DIST mi 0 OBD2 STAT CA/US Frame 10 Time 7.0 MIL STATUS OFF ABSLT TPS % 17.6 ENG SPEED RPM 2125 CALC LOAD % 18.8 MAF FLOW GR/SE 27.32 MAP KPA 77 COOLANT F 188 IAT F 60 IGN ADVANCE DE 49.0 ST FTRM1 % 1.5 LT FTRM1 % -4.9 VEH SPEED MPH 36 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.145 ST FTRM11 % -1.0 O2S12 V 0.730 MIL DIST mi 0 OBD2 STAT CA/US Frame 11 Time 7.7 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1761 CALC LOAD % 6.6 MAF FLOW GR/SE 12.00 MAP KPA 37 COOLANT F 188 IAT F 60 IGN ADVANCE DE 36.5 ST FTRM1 % -1.0 LT FTRM1 % -5.1 VEH SPEED MPH 37 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.700 ST FTRM11 % 0.8 O2S12 V 0.655 MIL DIST mi 0 OBD2 STAT CA/US Frame 12 Time 8.4 MIL STATUS OFF ABSLT TPS % 29.0 ENG SPEED RPM 1845 CALC LOAD % 9.8 MAF FLOW GR/SE 13.67 MAP KPA 40 COOLANT F 188 IAT F 60 IGN ADVANCE DE 27.5 ST FTRM1 % 0.0 LT FTRM1 % -5.1 VEH SPEED MPH 37 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.075 ST FTRM11 % 0.0 O2S12 V 0.105 MIL DIST mi 0 OBD2 STAT CA/US Frame 13 Time 9.1 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1568 CALC LOAD % 4.7 MAF FLOW GR/SE 7.28 MAP KPA 28 COOLANT F 188 IAT F 60 IGN ADVANCE DE 20.0 ST FTRM1 % 1.5 LT FTRM1 % -10.4 VEH SPEED MPH 36 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.790 ST FTRM11 % -2.2 O2S12 V 0.630 MIL DIST mi 0 OBD2 STAT CA/US Frame 14 Time 9.8 MIL STATUS OFF ABSLT TPS % 7.4 ENG SPEED RPM 1698 CALC LOAD % 10.1 MAF FLOW GR/SE 14.42 MAP KPA 44 COOLANT F 186 IAT F 60 IGN ADVANCE DE 45.5 ST FTRM1 % -1.0 LT FTRM1 % -6.3 VEH SPEED MPH 35 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.625 ST FTRM11 % 0.8 O2S12 V 0.255 MIL DIST mi 0 OBD2 STAT CA/US Frame 15 Time 10.5 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 980 CALC LOAD % 3.5 MAF FLOW GR/SE 7.78 MAP KPA 38 COOLANT F 186 IAT F 62 IGN ADVANCE DE 37.5 ST FTRM1 % -1.0 LT FTRM1 % -6.3 VEH SPEED MPH 33 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.760 ST FTRM11 % 0.0 O2S12 V 0.660 MIL DIST mi 0 OBD2 STAT CA/US Frame 16 Time 11.2 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 988 CALC LOAD % 3.5 MAF FLOW GR/SE 5.35 MAP KPA 32 COOLANT F 186 IAT F 62 IGN ADVANCE DE 20.0 ST FTRM1 % -1.0 LT FTRM1 % -11.6 VEH SPEED MPH 32 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.085 ST FTRM11 % -1.0 O2S12 V 0.690 MIL DIST mi 0 OBD2 STAT CA/US Frame 17 Time 11.9 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1020 CALC LOAD % 3.9 MAF FLOW GR/SE 6.03 MAP KPA 34 COOLANT F 186 IAT F 62 IGN ADVANCE DE 20.0 ST FTRM1 % 0.8 LT FTRM1 % -11.6 VEH SPEED MPH 31 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.720 ST FTRM11 % -3.4 O2S12 V 0.690 MIL DIST mi 0 OBD2 STAT CA/US Frame 18 Time 12.6 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1018 CALC LOAD % 3.9 MAF FLOW GR/SE 6.00 MAP KPA 34 COOLANT F 185 IAT F 62 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -11.6 VEH SPEED MPH 21 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.075 ST FTRM11 % 0.7 O2S12 V 0.695 MIL DIST mi 0 OBD2 STAT CA/US Frame 19 Time 13.2 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 870 CALC LOAD % 3.9 MAF FLOW GR/SE 5.99 MAP KPA 41 COOLANT F 185 IAT F 62 IGN ADVANCE DE 20.0 ST FTRM1 % 0.7 LT FTRM1 % -11.6 VEH SPEED MPH 10 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.085 ST FTRM11 % 3.9 O2S12 V 0.135 MIL DIST mi 0 OBD2 STAT CA/US Frame 20 Time 13.9 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 703 CALC LOAD % 2.7 MAF FLOW GR/SE 4.64 MAP KPA 43 COOLANT F 185 IAT F 62 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -9.2 VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.135 ST FTRM11 % 0.0 O2S12 V 0.660 MIL DIST mi 0 OBD2 STAT CA/US Frame 21 Time 14.6 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 715 CALC LOAD % 3.1 MAF FLOW GR/SE 4.71 MAP KPA 42 COOLANT F 185 IAT F 64 IGN ADVANCE DE 20.0 ST FTRM1 % 0.8 LT FTRM1 % -5.1 VEH SPEED MPH 3 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.620 ST FTRM11 % 0.7 O2S12 V 0.655 MIL DIST mi 0 OBD2 STAT CA/US Frame 22 Time 15.3 MIL STATUS OFF ABSLT TPS % 65.8 ENG SPEED RPM 2860 CALC LOAD % 47.0 MAF FLOW GR/SE 72.27 MAP KPA 100 COOLANT F 185 IAT F 62 IGN ADVANCE DE 30.5 ST FTRM1 % 3.1 LT FTRM1 % -5.1 VEH SPEED MPH 24 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.805 ST FTRM11 % 2.3 O2S12 V 0.650 MIL DIST mi 0 OBD2 STAT CA/US Frame 23 Time 16.0 MIL STATUS OFF ABSLT TPS % 69.4 ENG SPEED RPM 2854 CALC LOAD % 44.7 MAF FLOW GR/SE 69.25 MAP KPA 102 COOLANT F 183 IAT F 60 IGN ADVANCE DE 26.5 ST FTRM1 % 0.7 LT FTRM1 % -2.2 VEH SPEED MPH 35 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.505 ST FTRM11 % 0.0 O2S12 V 0.840 MIL DIST mi 0 OBD2 STAT CA/US Frame 24 Time 16.7 MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 3435 CALC LOAD % 57.6 MAF FLOW GR/SE 84.89 MAP KPA 101 COOLANT F 183 IAT F 59 IGN ADVANCE DE 21.0 ST FTRM1 % 0.0 LT FTRM1 % -2.2 VEH SPEED MPH 46 FUEL SYS 1 OPEN1 FUEL SYS 2 N/A O2S11 V 0.850 ST FTRM11 % 0.8 O2S12 V 0.900 MIL DIST mi 0 OBD2 STAT CA/US Frame 25 Time 17.4 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1471 CALC LOAD % 5.4 MAF FLOW GR/SE 8.14 MAP KPA 31 COOLANT F 183 IAT F 59 IGN ADVANCE DE 20.0 ST FTRM1 % -2.2 LT FTRM1 % -11.6 VEH SPEED MPH 45 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.755 ST FTRM11 % -2.2 O2S12 V 0.840 MIL DIST mi 0 OBD2 STAT CA/US Frame 26 Time 18.1 MIL STATUS OFF ABSLT TPS % 16.4 ENG SPEED RPM 2059 CALC LOAD % 18.4 MAF FLOW GR/SE 33.82 MAP KPA 97 COOLANT F 183 IAT F 59 IGN ADVANCE DE 54.5 ST FTRM1 % 0.0 LT FTRM1 % -6.3 VEH SPEED MPH 46 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.265 ST FTRM11 % 0.0 O2S12 V 0.790 MIL DIST mi 0 OBD2 STAT CA/US Frame 27 Time 18.8 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1396 CALC LOAD % 4.7 MAF FLOW GR/SE 7.17 MAP KPA 29 COOLANT F 185 IAT F 59 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -11.6 VEH SPEED MPH 44 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.160 ST FTRM11 % 1.5 O2S12 V 0.330 MIL DIST mi 0 OBD2 STAT CA/US Frame 28 Time 19.4 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1130 CALC LOAD % 3.9 MAF FLOW GR/SE 6.47 MAP KPA 40 COOLANT F 185 IAT F 59 IGN ADVANCE DE 20.0 ST FTRM1 % 0.8 LT FTRM1 % -10.4 VEH SPEED MPH 36 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.070 ST FTRM11 % -4.6 O2S12 V 0.780 MIL DIST mi 0 OBD2 STAT CA/US Frame 29 Time 20.1 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 923 CALC LOAD % 3.9 MAF FLOW GR/SE 6.12 MAP KPA 37 COOLANT F 186 IAT F 60 IGN ADVANCE DE 20.0 ST FTRM1 % -1.0 LT FTRM1 % -11.6 VEH SPEED MPH 19 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.675 ST FTRM11 % -2.2 O2S12 V 0.785 MIL DIST mi 0 OBD2 STAT CA/US Frame 30 Time 20.8 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 808 CALC LOAD % 3.5 MAF FLOW GR/SE 5.39 MAP KPA 40 COOLANT F 186 IAT F 60 IGN ADVANCE DE 20.0 ST FTRM1 % -2.2 LT FTRM1 % -10.4 VEH SPEED MPH 1 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.730 ST FTRM11 % 0.0 O2S12 V 0.775 MIL DIST mi 0 OBD2 STAT CA/US Frame 31 Time 21.5 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 681 CALC LOAD % 3.1 MAF FLOW GR/SE 4.75 MAP KPA 43 COOLANT F 186 IAT F 62 IGN ADVANCE DE 19.5 ST FTRM1 % 0.7 LT FTRM1 % -9.2 VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.195 ST FTRM11 % 0.0 O2S12 V 0.770 MIL DIST mi 0 OBD2 STAT CA/US Frame 32 Time 22.2 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 716 CALC LOAD % 4.7 MAF FLOW GR/SE 19.78 MAP KPA 75 COOLANT F 186 IAT F 62 IGN ADVANCE DE 30.5 ST FTRM1 % -3.4 LT FTRM1 % -5.1 VEH SPEED MPH 7 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.060 ST FTRM11 % -1.0 O2S12 V 0.390 MIL DIST mi 0 OBD2 STAT CA/US Frame 33 Time 22.9 MIL STATUS OFF ABSLT TPS % 36.8 ENG SPEED RPM 2441 CALC LOAD % 27.4 MAF FLOW GR/SE 42.79 MAP KPA 92 COOLANT F 186 IAT F 60 IGN ADVANCE DE 41.0 ST FTRM1 % 2.3 LT FTRM1 % -4.9 VEH SPEED MPH 20 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.115 ST FTRM11 % 1.5 O2S12 V 0.330 MIL DIST mi 0 OBD2 STAT CA/US Frame 34 Time 23.6 MIL STATUS OFF ABSLT TPS % 32.5 ENG SPEED RPM 2308 CALC LOAD % 26.2 MAF FLOW GR/SE 40.74 MAP KPA 97 COOLANT F 186 IAT F 59 IGN ADVANCE DE 39.0 ST FTRM1 % 3.1 LT FTRM1 % -4.9 VEH SPEED MPH 28 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.760 ST FTRM11 % 0.7 O2S12 V 0.530 MIL DIST mi 0 OBD2 STAT CA/US Frame 35 Time 24.3 MIL STATUS OFF ABSLT TPS % 20.7 ENG SPEED RPM 2478 CALC LOAD % 17.6 MAF FLOW GR/SE 31.87 MAP KPA 33 COOLANT F 185 IAT F 59 IGN ADVANCE DE 23.5 ST FTRM1 % 0.7 LT FTRM1 % -9.2 VEH SPEED MPH 30 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.070 ST FTRM11 % 1.5 O2S12 V 0.635 MIL DIST mi 0 OBD2 STAT CA/US Frame 36 Time 24.9 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 1006 CALC LOAD % 3.9 MAF FLOW GR/SE 6.15 MAP KPA 37 COOLANT F 185 IAT F 60 IGN ADVANCE DE 20.0 ST FTRM1 % -1.0 LT FTRM1 % -11.6 VEH SPEED MPH 13 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.105 ST FTRM11 % 0.8 O2S12 V 0.670 MIL DIST mi 0 OBD2 STAT CA/US Frame 37 Time 25.6 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 597 CALC LOAD % 3.1 MAF FLOW GR/SE 5.33 MAP KPA 48 COOLANT F 186 IAT F 60 IGN ADVANCE DE 20.0 ST FTRM1 % 0.0 LT FTRM1 % -11.6 VEH SPEED MPH 3 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.730 ST FTRM11 % 0.0 O2S12 V 0.195 MIL DIST mi 0 OBD2 STAT CA/US Frame 38 Time 26.3 MIL STATUS OFF ABSLT TPS % 0.0 ENG SPEED RPM 720 CALC LOAD % 3.1 MAF FLOW GR/SE 5.00 MAP KPA 41 COOLANT F 186 IAT F 60 IGN ADVANCE DE 17.0 ST FTRM1 % 0.0 LT FTRM1 % -9.2 VEH SPEED MPH 0 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.075 ST FTRM11 % 1.5 O2S12 V 0.100 MIL DIST mi 0 OBD2 STAT CA/US Frame 39 Time 27.0
map looks ok now, how is it shifting if accelerate normally? (not at wot)
try this engine on in P press the gas pedal to the floor real quick does the rpm needle go to 4000 rpm then kicks back if yes that is normal but if it chokes before that then continues you could have bad tps. Tps could have a glitch at idle should produce about .59V and voltage should increase progresivly on the graph it should look like a nice smooth curve slovly increasing with the rpm. Scope is the best for this but you can use dvom. Do not change any parts yet we are just testing now. Also check your transmission oil level and color. Disconnect your MAF it will choke at the begining when ever you step on the gas but tell me how is your car accelerating with maf disconected? |
also try this this will tell you about your transmission: shift in 3rd go about 35mph then shift into 2nd and see if you can feel the engine braking and increase of rpm, also shift into 2nd and go about 30 shift into 1st and observe the same thing then shift in D go about 50 shift into 3rd in all cases you should feel slowing down and rpm increase if not you have bad clutches in one of the gears. Change your trans oil and see if it helps.
I suggest you buy this http://www.jcwhitney.com/webapp/wcs/...atalogId=10101 for the future it will alow you to change oil from trans and engine within 5 min max. It comes with tubes that can fit inside of your engine and trans dipsitks and suck oil out from both pans. This way I keep my trans oil fresh and change it every year without raising the car. |
Frame 8 Time 5.6
MIL STATUS OFF ABSLT TPS % 100.0 ENG SPEED RPM 5160 CALC LOAD % 66.2 MAF FLOW GR/SE 18.82 MAP KPA 35 COOLANT F 176 IAT F 66 IGN ADVANCE DE 20.0 ST FTRM1 % -1.0 LT FTRM1 % -7.7 VEH SPEED MPH 40 FUEL SYS 1 CLSD FUEL SYS 2 N/A O2S11 V 0.850 ST FTRM11 % -5.1 O2S12 V 0.910 MIL DIST mi 0 OBD2 STAT CA/US Maf and Map reading are totally wrong on this frame at 5100 rpm your engine is not getting enough air, (only 18 g/s) and at 100% WOT your engine vacuum is about 20inHG like at idle and no load. It is possible that cat is restricted but you said you disconected it after the cat that, you had to do it before the cat. There is a way to test if you cat is cloged by using vacuum pump and measureing vacuum. Check this site on the bottom left for clogged exhaust http://www.users.bigpond.com/ergoff/vac2.htm |
It sounds like I here a slight restriction at the cat, but I cant see through it since the top angles up. I was thinking of cutting it off in front of the cat so I can see through it. When sitting in Park, it does rev to 4 g's and back off. I changed the tranny fluid and filter at about 50,000 miles. The tranny has a noisy bearing that whines when driving. This has been happening since around 45,000 miles. It has 82,000 miles now.
I drove to the next town today and it's the same as before. No power on the hills. Little power below 2,000 RPM's. Power surge at 3,000 RPM. Bogs @ 4,000 + RPM's really bad. I was going to chop off the cat and put a by pass of pipe there and see what happens. I took the cat off, but it was so loud, I wasn't sure what it was doing. It did spin the tires and the low trac light came on. But the noise made it hard to realize if it was running better. I was afraid the cops would hear it and come after me. The tranny seems to work fine. I will try disconnecting the MAF tomorrow morning. I'll see what happens with that. I will see if I can get a vacuum gauge to try to vacuum test.
Not sure what year your car is but I assume it is older model that has vacuum modulator.
so check your vacuum modulator if you have one it is possible that the vacuum line going to it is leaking or is not connected or the modulator itself is leaking trans oil.... if your modulator is bad trans will not shift right and will behave just like you explained |
I would try cleaning the MAF sensor with MAF cleaner see if that helps.
Your black fuel is from over filling your gas tank! The fuel gets sucked into the vents for the charcol canister up front and as its recirculated it contaminates your fuel. Could also faul out your purge valve in the rear by the tank. Might not hurt to check your fuel pressure, should be 41-47 psi on your 2002. The black fuel also can cause your injectors to operate poorly. ![]() Also test your secondary O2 since youve been running that contaminated fuel. You can reach the connector just behind the engine under the hood. Heres a link with that procedure. http://www.automotiveforums.com/vbul...d.php?t=672110
1999 Grand Am SS 3.4 OHV
I notice the last couple of test drives when I floor it and it bogs, it starts to have that sulfur smell. So I think this is the cat gone bad. I was too busy today to do the checks I was going to do. I'm also waiting for someone to bring me the pressure gauge to test the fuel pressure and a vacuum gauge to check the vacuum.
I disconnected the MAF and it had more power untill about 4000 RPM. It would not go past 4,500 RPM. I connected it back up and it still ran good until about 4,000, but after a little bit, then it started to be sluggish at lower RPM again.
