Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-04-2009, 07:25 PM
miamibob's Avatar
miamibob miamibob is offline
!995 GM Map Sensor Removal Tool
Hey Guys,
Does anyone know what size Torx Driver is used to remove the MAF Sensor on a '95 GM? I have down to an "8" but that seems too big. "6" maybe? Just don't want to buy what I don't need. Many thanks....Bobby
That is the sensor attached to the top of the Tube after the Air Filter on the Air Filter assembly - has the 2 filaments that you spray and a connector!! I put MAP by mistake in the Title.
Old 01-04-2009, 07:56 PM
miamibob's Avatar
Re: !995 GM Map Sensor Removal Tool
Sorry guys - I put the wrong sensor name in my title - I mean the MAF Sensor!!
Old 01-05-2009, 06:44 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Don't those have the tamper proof torx? If I remenber correctly, ours had a tamper proof head with the little dot raised in the center.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-05-2009, 01:04 PM
miamibob's Avatar
That's correct, my friend. Now what size tool removes them???
Old 01-05-2009, 01:42 PM
way2old's Avatar
TOKEN HILLBILLY
It is a T20 tamper proof Torx. Just went to a CV and checked the size. If you don't want to buy a tamper proof, just gingerly drill the dot out of the center. Then a T20 will work.
Old 01-05-2009, 07:39 PM
miamibob's Avatar
You're "The Man" as usual!! I cleaned the sensor today and it is indeed a T-20! Many thanks as usual - you NEVER disappoint me!!!!! Bobby
