Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 01-04-2009, 05:45 PM
markqc markqc is offline
Horn Not Working
The horn on my 2000 Silhouette stopped working recently. The horn will sound when I lock the doors.
How difficult is it to remove the cover on the center of the steering wheel in order to check the switch? Do you need to turn off the air bags or disconnect the battery? Any other suggestions?
Thanks,
Mark
Old 01-04-2009, 10:04 PM
roadrunner2 roadrunner2 is offline
Re: Horn Not Working
Thanks,
Mark
Get another opinion before you start.
Pull the fuse for the air bag.
Be extremely careful when working on the steering wheel.
If the air bag should go off accidentally, you could be hurt.
The problem with doing nothing is not knowing when you're finished.
Old 01-06-2009, 11:41 AM
rockwood84 rockwood84 is offline
after you disarm the airbag let it sit for ten to fifteen minutes to discharge the you can pull the center out of the steering wheel.once you get the center out lay it down in a place where it can't fall .the screws that hold the center on are underneath it.
Old 01-06-2009, 09:02 PM
I made a mistake when I said to pull the fuse. Well, more like didn't tell the Whole truth.
I re-read my maual and it recommends disconnecting the NEGATIVE battery cable and wait a few minutes. Sorry.
Old 01-07-2009, 06:15 PM
Thanks for your replies. How difficult is it to remove and replace the horn "pad" in the center of the steering wheel? I am concerned about getting it back on properly. Does the air bag need to come out or does it sit in its "compartment or pocket" while servicing the horn pad? I reallly don't want to mess with the air bag. You wouldn't happen to have a picture in your manual?
Mark
Old 01-07-2009, 08:12 PM
I can't send pictures as I don't have a scanner.
The problem may not be with the horn switch in the steering wheel.
While an assistant presses the horn switch on the steering wheel pad, test for battery voltage at the dark green wire terminal.
Check for continuity to ground at the black wire terminal.
If there is no voltage at the dark green wire terminal, check the horn relay, which is located in the underhood fuse/relay box. (Above the battery)
To avoid possible airbag inflation and injury, have someone with airbag experience help.
If you can, go to a library and look up the repair manual for your vehicle.
Other than that, go to almost any automotive store and check out the Haynes repair manual # 38036 P# 10-11 & 12 (under steering wheel removal).
Old 01-08-2009, 10:37 AM
does the cruise still work?
Old 01-09-2009, 08:53 AM
Thanks for the replies.
"The problem may not be with the horn switch in the steering wheel."
You may be right. I'll try your troubleshooting tip this weekend. The horn does sound when you lock the doors. Does the alarm circuit use a different fuse than the horn circuit?
"does the cruise still work?"
I'll try the cruise tonight. Is the cruise control on the same circuit?
Mark
Old 01-09-2009, 10:23 AM
if both the horn and cruise control don't work then its gonna be a broken clockspring under the airbag/center of steering wheel.......this will make the airbag light come on too.
Old 01-11-2009, 01:35 PM
The cruise control still works. I will need to check the fuse for the horn, but I'm sure this must be good as the horn sounds when setting the alarm.
Old 01-11-2009, 06:36 PM
most likely the horn contacts in steering wheel.......
Old 01-13-2009, 02:16 PM
billn2 billn2 is offline
If I remember correctly the horn circuit by-passes the clockspring and uses the turnsignal cancling cam to complete the circuit. If the horn sounds when you lock the doors, you probably need a horn switch. If memory serves me correctly on this one I believe the horn switch is part of the air bag. Make sure you check the continuity of the curcuit through the steering column before you condemn the air bag. There is a spring loaded contact that connects to the turnsignal cancling cam. Some times the cam breaks where the contact fastens and can no longer hold it down. The switch actually completes the ground circuit.
