Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 10-21-2001, 04:52 PM
P10DET's Avatar
P10DET P10DET is offline
P10 Radiator
At our geekout yesterday (where the SE-R folks whimped out for a change) I was examining howard_w13's radiator in his automatic equipped P10. Dayem! It's as thick (or thicker than) my aftermarket double row radiator.
So, I dug into the fiche last night.......
It turned up the following:
All auto tranny P10 use 21460-62J01
The manual gearbox P10 uses:
21460-53J00 or
21460-62J00
Next time some of y'all get together, would you please compare manual gearbox radiators vs auto tranny radiators? It looks pretty likely that the auto tranny radiator is a direct fit heavy duty OEM radiator. I would just like to confirm this before stating it as fact. That would be a really good thing to know. Granted, my aftermarket radiator was something like $150-175 (can't remember - I'm old ) and an OEM would run close to $300, but I still would likely have bought an OEM. Also, my aftermarket has smaller in/out fittings than OEM, so it has a rubber adapter to install the radiator hose.
So, can someone please confirm?
Might be a good idea for you P11 folks to check it out as well. Luke, their may be an easy radiator upgrade available for you. That may not be important on the street, but on the track it would be a big deal.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-21-2001, 05:01 PM
zykotik zykotik is offline
Send a message via ICQ to zykotik Send a message via AIM to zykotik Send a message via Yahoo to zykotik
So you think then (because my car used to be auto) when I get my DET in there I could get away with using my stock rad (if its in good condition)?
-Objects in mirror are losing-
www.npclub.com
Old 10-21-2001, 06:08 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
I'll go and check tonight and see if i have any pictures where i can compare my old auto with the 5-spd. here in Az I can definitely use all the help i can get. When it's 110+ outside it feels as though my car barely wants to run Maybe with a turbo in mind for the future, an aftermarket upgrade would be a samrter choice. Although for a cheap alternative (salvage yard) the auto radiator may be a very easy, wallet-friendly upgrade. Cool! hehe
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 10-21-2001, 08:09 PM
P10DET's Avatar
Could very well be. That's what I'm trying to determine.
George Roffe
Houston, Texas USA
00 328i
Old 10-22-2001, 04:02 PM
Apeman Apeman is offline
When I had my G20 turbo with the T3/T04E I used my stock auto radiator and it worked fine. I only had one overheating problem which was on a 35 deg C day when I had been stuck in stop and go traffic with the A/C on for about 30min. When the traffic cleared I floored it up to about 170kph and noticed the temp gauge had moved up to about 3/4. I slowed down and turned on the heater and it dropped back to normal right away.
I suspect my car would run hotter than a 5 spd G20 as it had an auto which creates more heat, although I was using an aux. tranny cooler.
Old 10-22-2001, 06:44 PM
Well with the fluctuating seasons and temps in our fine country I really want to avoid that. My poor ol Teg died becuase of a lack thinking on my part and I don't wanna have this happen to my G ride (it's better than my teg was )
If it means being safe and nothing is conclusive about using the auto rad I willl definitely want to go with an aftermarket solution.
It'd really suck to blow a DET
www.npclub.com
Old 10-23-2001, 08:23 PM
grant_nz grant_nz is offline
Radiator
I have a 1994 eGT auto and the radiator is very thick.
It also has the Calsonic brand sticker on it....so its definetly looks different to a standard P10....
Old 10-23-2001, 08:30 PM
JustinP10's Avatar
Actually i thought my old car had a calsonic sticker or badging on the rediator too, i think my car may have it too, i forget. But i have seen that before.
Justin McClanahan
95 G20
Old 10-23-2001, 08:33 PM
I have seen some people look at the back of the radiator and the front and say its very thick....but remember the aircon condensor is their also...
I have seen a couple of people make this mistake...
Old 10-23-2001, 10:53 PM
P10DET's Avatar
You have to look at the side at the core itself.
BTW, all OEM radiators for Nissan (that I know of) are made by Calsonic.
George Roffe
Houston, Texas USA
00 328i
Old 10-24-2001, 01:46 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Just wonderin...we're not including the A/C Condensor in this right? Would the radiator be different on a model with or without A/C?
-Brian Jones
I got a snake man
Old 10-24-2001, 01:54 AM
JustinP10's Avatar
I don't think there was a G20 offered without A/C, it may have been an option on certain model Primera's overseas, but i think it was standard here in the US.
Justin McClanahan
95 G20
5.2, Very hot in cab, radiator cold. mrspooks Ram Pickup | Ram SRT10 0 08-15-2009 08:55 AM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
1990 Ford Econoline Van Radiator Problem, I think.. ariel418 Econoline 6 05-12-2009 06:40 PM
Lower radiator hose cool/Water pump squeal ktl4974 Problem Diagnosis 7 05-04-2009 08:44 PM
Trans Fluid Leaking Into Radiator Coolant Wheels555 Venture 1 03-04-2009 06:18 PM
