Scan Tool
Does anyone use or own one of the over the counter scan tools(the $200 or so models)? I was thinking it might be a useful to have one in my tool box, for those times when the check engine light comes on. Between my cars and my kids cars it might get some use. If so, are any brand better than another? Thank You, in advance.
Re: Scan Tool
I'm gonna get one too and I've seen some on ebay for $30 (new) plus around $20 for shipping. All it does is read codes (OBD II), no live data like a $200 probably does. I think it'll be very useful.
Re: Scan Tool
You really need live data for any meaningful diagnostic capabilities.
Re: Scan Tool
I probably wouldn't understand most of the live data. I did manage to fix my old '93 GA once with just the code and that's about all you need and the cheap scanner has paid for itself. Live data would be cool though and I guy would probably start to understand after awhile.
Re: Scan Tool
http://www.levineautoparts.com/Equus.html Search Equus 3140 it gives 25 data streams and freeze frame. I had to buy a high speed cable for usb to update mine. I wanted something to update my 4000E which only goes to 2002.
If I need more a friend will let me use his Genesis at his shop but they run around $3500.00. This one is around $240.00 |
Re: Scan Tool
Re: Scan Tool
I always used my 4000E for the older cars. It won't pick up freeze frame. I get data on the older ones which I found out is very useful. I got this one because it will read can data. Otc wanted a yearly update and after I got of the garage business it didn't pay.
Re: Scan Tool
Re: Scan Tool
Be advised that the scanner or code reader you plan to use on the 2000Silverado will not work on anything built prior to 1996. On those models, you can jumper 2 sockets in the vehicle plug to get the codes.
Re: Scan Tool
The scanners will work on both if you look at the one I suggested it has cables for both. The ones that cost more will work. The cheaper ones won't work. You get what you pay for in scanners.
Re: Scan Tool
Re: Scan Tool
