Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-04-2009, 11:02 AM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
installing a new alternator
Are there any tricks i should know? How tight should i make the belt because i'm worried about over/under-tightening it.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 01-04-2009, 11:52 AM
463's Avatar
463 463 is offline
Re: installing a new alternator
here is a link that will explain this for you. http://www.autozone.com/shopping/rep...00c1528005c59a
Old 01-04-2009, 04:36 PM
j cAT j cAT is offline
when first installing tighten so that the belt will deflect 1/4 inch or so,at the mid point when you push down on it...then try to rotate the alt pulley by hand....after a few days re-tighten so that the belt is as before...
it is better to be loose ,, than too tight , as the bearings will get damaged..
