Old 01-04-2009, 02:44 AM
vr4choke's Avatar
vr4choke vr4choke is offline
Send a message via AIM to vr4choke Send a message via MSN to vr4choke
1000 internet dollars
what, in your opinions, would be the best way to spend $1000 on mods for my 91 stock vr4? i was thinking of using it all on an exhaust or wheels but i would rather spend it on more than one area. all ideas welcome!
Old 01-04-2009, 09:23 AM
vectorspecialist vectorspecialist is offline
Re: 1000 internet dollars
pretty sure you could get stage 1 for around 1g. if not, a tune up if needed. boost controller, fuel injectors, spark plugs, other basic thing, fuel filter. a really good look over by a trusted mechanic.
yup, here i am
Old 01-04-2009, 12:58 PM
AutostradaVR4 AutostradaVR4 is offline
if your careful enough, you might be able to do exhaust, intake, MBC, datalogger, and brakes (pads, rotors, lines)
are you current on your 60k/120k services?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 01-04-2009, 02:15 PM
Girly VR-4 Girly VR-4 is offline
stage 1? I wasn't aware that there WAS a stage one...
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 01-04-2009, 06:50 PM
vr4choke's Avatar
oh yeah! that completely slipped my mind, but i am about to hit 60k. what is supposed to be replaced for that tune up? i know its one of the big ones.
Old 01-04-2009, 08:00 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Timing belt, oil pump, water pump are the main things. Very importanat you do that and if you hire someone to do it that is where your money will go.
Old 01-05-2009, 12:43 PM
do that NOW!!
It's supposed to be done every 60k miles, or 6 years (regardless of miles). Those belts dry rot, and all sorts of things like to go bad.
www.3swarehouse.com
Old 01-05-2009, 06:37 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
First thing Deffenetly get a 60k kit and get that done. Here is a Kit I would suguest-
http://www.pricematchedparts.com/pro...it-1599-0.html
That is the Kit I run on both of my vr4s
Then when that is done I would look at doing some other things like a MBC and Boost gauge (as everyone will tell you they should be done together) If you want to stay on the cheap side you can go with something like a prosport gauge and a Hallman ES MBC. Here is a link-
http://www.pricematchedparts.com/cat...ges-433-1.html
and
http://www.pricematchedparts.com/cat...ers-170-1.html
I would stay away from MBC that are bleeder style valves. (TurboXS for example) You want to find one that is a ball and spring style. (Like Hallman)
If don't want to get out of the car and under the hood every time you want to adjust the boost you might look at this 2 in one.. EBC/Gauge controller-
http://www.pricematchedparts.com/pro...-1071-170.html
Depending on what set up you pick you will probably have enuff to buy an Intake, and downpipe
Thats what I would do..
