oversized oil filter
What are the pros and cons of using a oversized filter on a civic engine???
nothing?
2002 Acura TL Type S 1991 Honda Crx Si |
i think if you use a oversized oil filter you will increase oil capacity(but not much) and if your car has a vtec engine it will lower the oil pressure and it may cause some prblems with vtec cause it may not have enough oil pressure. if you don't have vtec don't worry about it. this is true because people who have b series vtec's can use the k series rsx type r or civic type r filter cause they are smaller and this causes the oil pressure to increase causing less fluctuation during vtec.
1994 civic ex - b16a sir2 w/lsd too much to list http://www.cardomain.com/memberpage/423478 |
Re: oversized oil filter
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
http://www.inlinefour.com/honoemoilfil.html very reputable people
Don't Worry...
Guys (and Gals), I've been an F-16 Fuels mech for some time now. Look at the two filters. They both have the same diameter inlet holes, and the same diameter outlet holes. As far as decreased oil pressure is concerned, the same bypass relief spring (at the top of the filter) is in both filters, which would produce equal flow pressure. One HUGE advantage to the larger filter is MORE FILTERING MEDIA, which can trap more dirt and other contaminants in the oil before getting clogged, in which case bypassing oil (ie: not filtering it). The only other difference is that the larger one has more capacity, which is good. Given that, more oil capacity equals somewhat lower oil temp (bigger filter to disperse more heat), plus more oil in which to disperse contaminants. Honda has officially "ok'd" the use of the larger filters on all new Honda Civics (I use one on my 2003 HX with 15,000mi on it).:huh:
Never let a promising career stand in the way of a good joke!! Last edited by K@mik@ze; 04-13-2003 at 06:50 PM. |
Re: Don't Worry...
Read this http://www.leecao.com/honda/vtec/dohcvtec.html Last edited by B16EJ1; 04-13-2003 at 07:33 AM. |
I was wrong about the operation of the VTEC system. I'm now a more informed person. Thank You.:eshooter:
Never let a promising career stand in the way of a good joke!! |
Hey thanks for the insight on filters.
