Old 01-03-2009, 05:53 PM
sumi123 sumi123 is offline
Can I adjust toe out?
I have a 92 Lumina sedan with 150,000 miles on it. Power steering and 3.1 engine. I have noticed that my my right front wheel is toed out. Is this an adjustment that I can do so both wheels track the same or is it a job for an alignment shop? I have to steer to the left slightly to drive straight.
Thank you.
Old 01-03-2009, 09:19 PM
Blue Bowtie's Avatar
Registered Offender
Re: Can I adjust toe out?
If you can loosen the tie rod sleeves (they are usually rusted) and can measure carefully from the inside of straight wheels, you can set the toe properly. This is the way it was done for decades before the advent of optical systems, and if done properly, is just as accurate.
Old 01-03-2009, 11:11 PM
Thanks for your response. I'm going to try it tomorrow and I'll let you know what happens.
Thanks again!
Old 01-04-2009, 08:56 AM
Registered Offender
Make sure you have the toe specifications, and that the steering rack is not worn or damaged. Keep the steering wheel straight, and keep the front wheels loaded and vehicle level. There are turntables made for this purpose.
Old 01-04-2009, 09:43 AM
maxwedge maxwedge is offline
A990 racer
Good info, but unless the rear toe is right, the wheel will not be straight as this is not a thrust line adjustment.
Old 01-04-2009, 10:10 AM
Registered Offender
Excellent point. Keep sight of the "big picture" when performing any alignment work. Another major consideration is ride height, especially side-to-side heights on the front of wrong-wheel-drive vehicles. A drive axle with a lower drive angle will tend to pull the vehicle in that direction.
Old 01-06-2009, 11:32 AM
Just an update - too rusted! Off to the shop we go! Thanks for your help.
