Old 01-03-2009, 02:55 PM
harley2457 harley2457 is offline
Unhappy 95 Blazer 4.3 Vortex
My blazer starts then shuts off, pump the gas at start up it will run at a higher rpm. Recent tune up and I tested the fuel pump and regulator, they're good. Can it be a coil or madulator going bad?
Old 01-03-2009, 04:52 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 Blazer 4.3 Vortex
What engine and what is the fuel pressure readings?
Any check engine lights or security lights?
Does it run like 2 seconds and the shut down?
MT
Old 01-04-2009, 10:07 AM
Its a 4.3 Vortex it holds 62 lbs for about two seconds and then drops to 20 lbs. Does it ever time. Took off plemuim and passenger side looks washed, had someone turn on key several times and there is no signs of leaks and I don't see any gas laying in there. Do u think maybe its a problem with the fuel pump?
Old 01-04-2009, 10:57 AM
MT-2500's Avatar
AF - Advisor
The fuel pressure is leaking off or the fuel pump is bad.
Block off return line and check for full pump pressure and leak down.
Full pump pressure should be around 95 or more lbs of pressure and hold pressure with return line blocked off or at fuel filter in line.
If not your fuel pump is bad.
Good Luck
MT
