Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 01-02-2009, 08:46 PM
Joe V. Joe V. is offline
Bplacesad paint
A little while back, I had my 1988 Vette repainted. Soon after that the paint started to blister in some places. He stated that it is due to oil in the original factor paint. Do you know if that is an inherent problem for that year? If he is full of bull, what most likely could have causd the problem?
Old 01-02-2009, 08:59 PM
Re: Bad paint
I am .retired, plus I am a student. In adddition ,I am on a fixed income, hence my funds a very limited. I really can't afford to pay to have it repainted. Can you help me?
Old 01-03-2009, 08:58 AM
rhandwor rhandwor is offline
Re: Bplacesad paint
I would say he didn't do the job correctly. I would really press him to fix it free.
If he was aware of the problem he should have removed the old paint. Sanded it off primed it and then painted the car.
A good paint job is expensive. A friend is rebuilding a 1937 Ford pickup and paint alone is $200.00
Old 01-05-2009, 02:10 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Bplacesad paint
Ditto with rhandwor...if he knew of the "defect" he should have compensated for it. You don't mention where the blistering occurs, but a true factory paint contamination would be dispersed more or less over the entire body, and if it were oil contamination, I doubt it would have passed inspection for Corvettes. More common would be localized contamination...drips from various fluids onto the fenders, gas dripping onto the paint, etc., or aerosolized drops landing hither and yon. The car should have undergone a thorough wash and dry, sanding to remove the existing clearcoat, roughen the surface, and remove oxidation, air blow-off and tack cloth to remove dust and surface contaminants, then shoot it with the paint.
I'd bet his equipment wasn't completely cleaned out and purged with fresh paint prior to starting to paint the car. This could explain blistering or other defects on one section of the car where he started to paint...or continued after having to mix up more to finish the coat.
Of course, more info would help, but hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
