Old 01-02-2009, 08:35 PM
crazy_ndn604 crazy_ndn604 is offline
Parasitic Draw?
has anybody had this problem with their cavalier? i have a 95 cavalier.that seems to be having this problem. tested the alternator. it put out 14.9 volts to the battery. but i went threw 2 batteries from repediatly draining them and re charging them. everything's stock electronically except for compustar alarm, and jvc deck. any help is appriciated. thanks
Old 01-02-2009, 09:09 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
Re: Parasitic Draw?
The only way i have found to find excessive battery drain is start pulling fuses. If you hook a ammeter in series with the battery (usually between the negative battery post and cable) wait a few minutes for the computer to go to sleep and then pull fuses one at a time and watch for a drop in the reading on the meter. Its kinda time consuming but it works. If you have recently added the car alarm and/or jvc deck i would unhook it and see what happens.
Old 01-02-2009, 09:11 PM
Re: Parasitic Draw?
yah i got myself a multi meter the other day. i was just hoping someone else ran into this problem and knew what was shorting or whatnot. so i can test that fuse. but i will try that. what should the meter be reading? thanks
