Old 01-02-2009, 12:54 PM
jcmodde jcmodde is offline
1991 S-10 4x4 "Check Gauges" light
Bought the truck used with 109875 miles. It was out of time so I timesd it, changed plugs, wires, oil, filters. As I was test driving after all this, after about 30 miles the Check Guages light came on and it started to run real crappy. Could not get over 40 mph. The oil guage dropped from just over 40 to "0". Limped it home. Not real good at diagnosing but can fix after it has been. Thinking maybe oil pump?
Old 01-02-2009, 05:57 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1991 S-10 4x4 "Check Gauges" light
Test oil pressure with a manual oil pressure test gauge.
Any check engine lights on?
MT
Old 01-24-2009, 07:12 PM
silveradocar silveradocar is offline
I think its a oil pressure problem not engine problem.
Chevy Silverado Tail Lights
Old 01-24-2009, 07:25 PM
discnik discnik is offline
Just double checking.
You said you did an oil change. I presume you re-checked the oil level once you got home ?
When you replaced the oil filter was the oil filter gasket ring still on the old one. I have had the old ring remain on the block and not notice it and ended up with one helluva mess.
Just a thought.
